Really need help with crazy idle issue. TRIED IT ALL
Old Nov 19, 2017 | 05:18 PM
lilhalfsquat54's Avatar
Icon5 Really need help with crazy idle issue. TRIED IT ALL
So i am at the end of the rope with my idle issue on my 89 hatch. The car will start if i give it gas and try to idle and will usually idle around 2000 rpms then ease its way down to about 1200 then spike back up. and sometimes it will just drop and stall out. once it gets to about 1000 rpm it feels like it wants to die and runs a little rough. it was a dpfi car but i converted to mpfi. it has a new headgasket and rebuilt head. it drives great and makes good power for a d16. so far ive tried the following
New head gasket and rebuilt head
New ecu
New idle air control valve
New dizzy
New intake air temp sensor
New coolant temp sensor
Bled cooling system
New plugs and wires
Checked for vacuum leaks and replaced intake manifold gasket
New skunk2 throttle body and intake.
i cannot get it to idle low enough without it dying and the idle is never steady. im at the end of the rope and desperate and made an account just to ask for some advice. some help or suggestions would be greatly appreciated and like i said, im new to the forum so be easy on me!
Old Nov 20, 2017 | 05:25 AM
scelestus's Avatar
Default Re: Really need help with crazy idle issue. TRIED IT ALL
No Check Engine Light?
Did you use a swap harness of some kind or did you modify the DPFI harness?
Did you calibrate the TPS?
What fuel rail and pressure regulator are you using?
Old Nov 20, 2017 | 10:18 AM
its a d16y7 fuel rail and regulator i had to use to mount on the skunk2 intake. also no check engine light. and tps has been calibrated but probably needs to be done again because i have even tried to adjust the throttle blade screw to get it to stay running. and i modified the original harness for the swap.
Old Nov 20, 2017 | 09:20 PM
acmoc's Avatar
What size is your throttle body?
You might need a smaller one
Post a photo of your throttle cable, it needs to have slack
Old Nov 21, 2017 | 12:48 PM
I purchased the skunk 2 alpha series thinking it would help with issue but still idles like crap. And I read online about the slack in throttle cable and it definitely has slack. It's not loose but not pulling the blade open at all and the throttle cable is a new honda oem cable
Old Nov 21, 2017 | 02:04 PM
DaX's Avatar
DaX
Loved
Community Favorite
Have you checked the resistance on your EACV? Unplug the harness and check the resistance across the the two pins on the EACV (not on the harness). It should be 8-15 ohms.
Old Nov 21, 2017 | 05:32 PM
is that the "idle air control valve"?
Old Nov 22, 2017 | 02:54 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yes, sorry, IACV and EACV or sometimes used interchangeably.
Old Nov 22, 2017 | 01:12 PM
ok I will give that a shot when I get home after work. Thanks
Old Nov 22, 2017 | 06:23 PM
acmoc's Avatar
Remove and clean the iacv
There is also a screw on top of the TB, screw it in all the way and see if it helps
Old Nov 22, 2017 | 07:37 PM
Thank you for the reply but I have cleaned the original iacv and it didn't help so I bought a new one and still no luck. It seems to idle really steady tho when the iacv is unplugged but when it's unplugged and I apply the gas it'll act like it hits a rev limiter around 3-4000 rpms and just bounces the rpms unless I go full throttle then it'll get past the "rev limiter " behavior and go to redline quickly
BlackLX4
Feb 23, 2016 05:45 AM
Afflicted1
50
Mar 4, 2014 09:46 PM
sleepers91hb
10
Apr 5, 2012 10:30 PM
saikouEF8
Jun 15, 2006 04:31 AM
89 CRX SI
Dec 14, 2002 05:35 PM
