Del Sol AC button won’t stay selected
Old Nov 15, 2017 | 06:18 PM
gumbyman2000's Avatar
Default Del Sol AC button won’t stay selected
Searched but couldn’t find a similar issue. In my 97 VTEC Del Sol, the AC button will push in and light up just fine, it just won’t stay selected. If I hold the button on in while the blower is running the air gets super cold, so I guess it is just something up with the button.
Questions:
1) How hard is this to deal with myself?
2) Is there documentation somewhere if it isn’t too difficult?
3) If this is a bit beyond my abilities how much would you suspect a repair shop will charge (TX)?
Here it is in action:
Also, thanks to the forum for answering my last question (without you even knowing) about the stupid little plastic doohickey on the clutch pedal that stopped the car from starting.
Old Nov 16, 2017 | 04:46 AM
mk378's Avatar
Default Re: Del Sol AC button won’t stay selected
You will need to replace the whole control panel. This is not real difficult to DIY. It is discontinued by Honda so you will need to find a used one. Be sure to detach the hot/cold mechanical cable from the heater box before trying to pull a panel out of the car.
I would also endorse simply jamming a toothpick in beside the button to hold it down when you want A/C.
Old Nov 16, 2017 | 07:12 AM
94eg!'s Avatar
#1 Super Guy
Loved
Try using a thin wire hook to pull the button out and see if the push-switch inside works without it. I use a hook-style spark-plug-gaping tool. I do this in my 94 Civic. Doesn't really fix the problem, but may provide a temporary solution. Also if it does work, then you may be able to modify your button cover to push the switch in a little further.
Just throwing out ideas.
Old Nov 16, 2017 | 04:07 PM
I’m all for a slightly dodgy fix.
Thanks very much much for the replies. I was hoping there was a non-replacethewholething option.
Old Nov 16, 2017 | 05:09 PM
tamboo's Avatar
10 Year Member
car-part is great for used parts:
Car-Part.com--Used Auto Parts Market
Old Apr 25, 2024 | 04:29 AM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
I'm gonna do something I never do, which is come out of lurking to revive a long dead thread. But I will this time, because replacing the entire climate control unit because of a broken switch is frankly, fking retarded. Please do not do this if you have the smallest bit of technical skill, or willingness to get your hands a little dirty. Instead, replace the switch on the board with a suitable alternative like:
Purchased from DigiKey or Mouser. The switch costs around $2.50. A soldering iron, desoldering braid and some solder will run you less than 10 bucks. There are six pins to solder.
Might take just a little bit of shimming on the board when reinstalling. This switch has a slightly longer throw than the OE one, by 1.5mm or so.
But the end result is a fully operational AC button. Bonus that the brand-new switch feels fantastic in terms of tactile feedback.
Old Apr 25, 2024 | 08:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
VERY productive necro bump... well done.
Old Jul 11, 2024 | 03:53 PM
Jared75's Avatar
Any chance you have a part number for Digikey so I may order one before I pull the old unit apart.
Old Jul 11, 2024 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
This would be most helpful for future searchers.
Old Jul 14, 2024 | 07:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
It's most likely due to bad/failed solder joints inside the climate control. Disassemble ble the climate control down to the circuit board and re--flow all the solder joints.
​​​​​​On my car I actually took the button cover out and jam a wooden bbq skewer over top of the board. The pressure on the board causes the AC compressor to kick on.
Old Jul 19, 2024 | 05:23 PM
Jared75's Avatar
Mine ended up being the switch. found a direct replacement from Mouser. part # 688-SPPH110800. Current cost was $2.63. let's get rid of the toothpicks.
Old Jul 19, 2024 | 05:26 PM
Jared75's Avatar
found a Mouser # 688-SPPH110800. direct replacement.
Old May 1, 2025 | 08:35 AM
HalfAnP's Avatar
My bad folks. I went right back into lurk mode after posting that. I could have *sworn* that I'd included a picture of the switch I used. Apologies for the missing info.
The switch P/N I used was
Old May 1, 2025 | 08:36 AM
HalfAnP's Avatar
This one is perfect. USE THIS ONE.
ray559527
Aug 28, 2011 04:19 AM
DohcSolz
Jun 13, 2011 06:38 AM
Tyconway
Jul 30, 2008 09:32 PM
eric.
Aug 8, 2004 03:28 AM
TriggerHappy101
Mar 21, 2004 08:49 AM
