Climate control unit
Old Nov 13, 2017 | 08:34 AM
Reids Del Sol's Avatar
Default Climate control unit
I found a post on how to remove the climate control unit from my 94 De Sol. Got it unfastened and almost out but could do see or reach the cables attached to the climate control pivoting lever. It is blocked from view (from the bottom through the radio cavity). What is the trick?
thanks
Old Nov 13, 2017 | 11:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Climate control unit
You need to detach the cable at it's opposite end. It's clipped to the blend door mechanism underneath the dashboard in the passengers foot-well. Once you un-clip it and slip the looped end off its post, the HVAC controls should slide out with the cable (as long as you have all the wire harnesses unplugged).
Old Nov 13, 2017 | 01:12 PM
mk378's Avatar
+1 Disconnect the other end. The mechanism is on the bottom of the heater box right over the "hump" in the middle of the car and may be more easily reached from the driver's side.
Handle the climate control unit carefully. The 25 year old plastic is going to be brittle. Do not try to detach the cable from the control panel end unless you absolutely have to.
DOHCter VTEC
Jan 21, 2008 09:03 PM
0ptimus prime
Mar 30, 2004 06:23 PM
Mr.Integra
Sep 6, 2003 12:58 PM
