b20b ek swap engine codes
Old Nov 11, 2017 | 11:22 AM
EKDiaz's Avatar
Icon4 b20b ek swap engine codes
i have a b20b non vtec swap in my ek coupe with a automatic obd2b computer (i have a p28 ready to be chipped computer just waiting for my obd2 to obd1 jumper harness to come in) and recently my rpms started to jump up and down when idling and sometimes when moving in gear it feels like it wants to bog out. The check engine light is flashing showing me about 7 different codes but im not sure what they can be considering i have the incorrect computer. Should i just wait till i can put in my p28 in and then run it for codes or can i still use the codes its giving me now???? If someone knows whats happening lmk. I need help pleasee
Old Nov 11, 2017 | 01:42 PM
mk378's Avatar
Default Re: b20b ek swap engine codes
The idling is because the auto OBDII uses a 3-wire IACV which you no longer have. Also your fuel maps are for a 1.6 liter engine but now you have 2.0. Surprising it drives at all like that.
Old Nov 11, 2017 | 03:27 PM
tony_2018's Avatar
Fish Twig
They should know better than to run any other ecu other than either a p75 5spd or a 5spd chipped ecu with a proper basemap.
Old Nov 11, 2017 | 03:30 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Or if you can find one, a USDM b20 ecu
Old Nov 11, 2017 | 03:38 PM
eghatch9295's Avatar
Stancetard Hate Monger
i have a usdm m/t b20 ecu.
Old Nov 12, 2017 | 04:38 AM
EKDiaz's Avatar
it was idling fine just a few days ago thou . it just recently started jumping up and down in the rpms using the same computer.
Old Nov 12, 2017 | 04:43 AM
EKDiaz's Avatar
the check engine light threw code 54 and i looked at the codes for obd2 and it came up as crank fluctuation sensor. Could this be the reason????
Old Nov 12, 2017 | 05:20 AM
mk378's Avatar
Again the CKF is a part that the OBDII Civic ECU expects to find, but is not on your engine.
You really should stop driving the car until you get the proper ECU installed.
Old Nov 12, 2017 | 05:37 AM
EKDiaz's Avatar
alright thanks man
710dabber
Jun 21, 2015 11:26 AM
augie1209
Engine Management and Tuning
Oct 18, 2012 12:09 PM
Bioinfomatic
Jan 29, 2007 04:22 PM
matman4444
Jul 23, 2004 06:16 PM
