5 quarts and still reading low on dipstick
Old Nov 8, 2017 | 02:10 PM
Mason Edmison's Avatar
Default 5 quarts and still reading low on dipstick
Kinda of a noob question here, but nonetheless, I am confused. Did an oil change on my 2000 Accord 2.3 L this afternoon. When filling it up with oil I put in 4, dropped it on level ground, added little by little. I ended up putting in in the whole 5 qts and Im still reading a bit below the full dot. I know the capacity on this car is 4.5. Yes, the car was warm and I let it cool for a few minutes before checking the oil. I also drove it around, let it cool again and same story. Just a bit below full. Should I top it off? Then I would be at 5.25 qts. appx.
FWIW I had the car on jack stands to ensure I got all the old oil out. Is this reading off or what?
Old Nov 8, 2017 | 09:24 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 5 quarts and still reading low on dipstick
5.6 Quarts is what a dry engine will take.If you drained your engine well you could be close to that.
Old Nov 10, 2017 | 09:08 AM
2001GSRSC's Avatar
5 Year Member
Piston skirts, walls, and oil galleys with a new empty filter could very well retain 1 quart of oil.
That said..
My Accord fills with 4.5 , after any reasonable draining .
Metaccord
49
Apr 18, 2014 02:27 AM
sasanj
42
Apr 10, 2012 03:09 PM
jfernandez1977
Jul 27, 2008 05:50 PM
Xxcivic99xX
Aug 12, 2004 10:27 PM
94GsRacer
Sep 19, 2002 02:43 PM
