What did you change between the two tests? The first one was running obscenely rich. The second one is probably also too rich. You should look at fuel pressure. Check that the engine warms up to operating temperature so it goes closed loop, and that the ECT and IAT are within spec measured with an ohmmeter. Also inspect the spark plugs, if one is different from the others (like black), that cylinder may have a bad injector.
DC Headers, AEM Short Ram, Believe That's All, Right Now.
Stock ECU is Possible But Would Have to Purchase one (P28 or P08) * Previously was running it with H22 fuel maps & got it Remapped To Stock D15b Maps. [P06 Chipped & Converted VTEC]
Valve Cover Gasket has a Tiny Leak Gonna Replace it.
Cant Remember When i Changed Spark Plugs But Their Fairly Cheap So Might Do it Again. Wires are Brand New.
Had a similar problem years ago, I had my injectors cleaned/rebuilt locally and it solved the problem. Best guess is that they were so old and gummed up that they probably never fully closed when they were supposed to.
check the cap good, i had a rotor screw come out once and it wasted the pickups
also not hating but where you getting your maps from, there are some good guys in the ecu forum, you might see if they can take a look at the test results and see if they think its a map issue,
From A Local Tuner, Hes Not So Bad Alot Of People Recommend Him, His Base Map Was From Crome For The Jdm D15b.
The Screw Did Fall Out Never Would've Known If i Never Took The Cap Out To Check, Rotor Was Still On Somehow, Screwed it Back in After Not Seen Any Visible Damage.
My Hopes Are High For This 3rd Smog Check & The Smog Shop is Giving me 2nd Retest After Paying Full Price For Just The First One.
Flash a totally stock map, or remove the jumper so the ECU runs stock firmware instead of from the chip, or use a stock ECU.
Things I've asked you before: Coolant temperature proper (193 degree thermostat installed and working)? Valve adjustment good? Any signs of misfiring? Any difference in color between the spark plugs?
