1991 CRX SI/ B20 Code 3 MAP
Old Nov 7, 2017 | 07:14 AM
existanzcivicb20's Avatar
Icon5 1991 CRX SI/ B20 Code 3 MAP
Car is CRX SI I swapped it with a B20B and car runs great until I go to full throttle I get a Code 3 MAP sensor code and then the car runs like crap. I have to turn the car off and restart it so it will run good again. The engine runs strong as long as I do not go to full throttle. Only upgrades I have on the engine is ITR headers, Skunk 2 Pro series Intake manifold and Throttle body, and 2.75" exhaust.
Things I have checked:
Timing is good ( checked with test light)
Swapped out the MAP with 3 other brand new sensors
TPS is good and calibrated
I have 3 ECU's that I have tried. P28 chipped, 2 x P75 virgin
Fuel Pressure 28psi at idle with the vacuum line connected to the FPR and 38psi disconnected
Old Nov 7, 2017 | 08:25 AM
Creator's Avatar
Default Re: 1991 CRX SI/ B20 Code 3 MAP
The TPS and the MAP sensor have the same plug, make sure they're not swapped. Although I doubt you would get very far with those swapped. I feel like you may want to revisit the TPS.
Old Nov 7, 2017 | 10:28 AM
I have tried to swap the plugs and the car runs like crap and I get TPS and MAP codes. I have also tried 4 different TPS sensors that I had laying around.
Old Nov 9, 2017 | 07:16 AM
scelestus's Avatar
Check your wiring? My 91 hatch had intermittent/random sensor codes when I bought it, swapped sensors over and over, finally figured out that there is one wire (green/white I think) that's common to most of the IM wiring on OBD0 - did you do a full harness swap or just get adapters? Pretty sure OBD1 is similar regardless. Anyway, some previous owner smashed/crimped/shorted something somewhere on mine. Even though it was fouling all my sensors it usually only threw one code- either MAP or TPS. I eventually ran a new wire from ECU to the strut tower plug- not proud but it worked. Google around and you should be able to find the Helms diagrams, they're a godsend.
Codey
Sep 22, 2016 11:16 AM
regal1975
Jun 6, 2014 08:46 AM
Gabe Gamble
Aug 7, 2011 03:26 PM
Quarter Performance
Nov 30, 2008 07:37 PM
MugenizedR
Nov 1, 2003 03:43 PM
