94-97 Accord Stainless Brake Lines Question
For those who've done the rear disc brake conversion (LX model with EX rear brakes), which stainless steel brake lines did you use? Online I've seen Goodridge sells a 4 line kit (with drums) and a 6 line kit (rear disc with ABS). I don't have ABS but do have rear discs. Can anyone give me some insight on which set to use? Thanks in advance!
Check out this diagram. The brake lines are #3. Between the soft lines though, there is #7 which is a hard line that is mounted along the trailing arm. so that is why you need the 6 line kit. Brand wise I recommend Goodridge for the kit. Quality is top notch and it comes with all kinds of extra clips and hardware which is great.
Wdpfreak145
10
Mar 28, 2013 10:48 AM
