HELP! Engine not start
Civic D15B2 EG8 93 1.5 16V
Hi guys and girls. I have a problem. My engine doesn't start.
I have a problem, the engine is spinning but it does not start. The pump works, everything works as it should. Engine c4g, manifold c5g, ecu c5g wires c5g, c5g splitter
new sparks, new filters, new oil. etc......GO engine.
seems like ages that this engine has to work.
Are you sure you have spark? You should have blue spark at each plug. check by touching each plug to engine head with the plug wire connected. Use a plier .
If you have good spark then just try some break cleaner in the intake while cranking.
acuraTboo
Honda Civic (2006 - 2015)
Apr 24, 2013 04:16 AM
sleepystyle
Sep 24, 2006 07:34 PM
