99 EX strut tower bushings??
Old Nov 4, 2017 | 05:05 AM
Baby99EX's Avatar
Default 99 EX strut tower bushings??
Hello,
can anyone help me out with a part number or place to order the bushings for the bottom of the strut towers please and thanks??
Old Nov 4, 2017 | 08:17 AM
oneheadlight's Avatar
Icon7 Re: 99 EX strut tower bushings??
Originally Posted by Baby99EX
Hello,
www.collegehillshondaparts.com
Majestic Honda - The Internet's #1 Honda Automotive Parts Store
to name a couple.. just use their website and look up the parts, you can find the part numbers there. Not difficult to do. Good website layouts.
Old Nov 4, 2017 | 08:28 AM
Baby99EX's Avatar
Default Re: 99 EX strut tower bushings??
thanks man, but they dont have what i need........
https://dz310nzuyimx0.cloudfront.net...98797ee414.gif
i need the bushing that is right above the bolt on #20, as u can see,its not even a selectable option.....
Old Nov 4, 2017 | 08:34 AM
oh that's the rear trailing arm bushing.. Lots of aftermarket options. I don't think Honda sells that separate from the trailing arm. Even though you can press it out and replace it. Hardrace should have one if you want rubber, and Energy Suspension should have one in polyurethane.
hardrace here's their part number
HARDRACE GLOBAL - REAR TRAILING ARM BUSHING?6115
Energy suspension if you want polyurethane.. Hardrace is rubber.. some like it since it's less vibration..
energysuspension.com | parts search
looking at both I'd probably go with Hardrace if it was me.. The energy suspension doesn't have the mounting part of the bushing.. meh, I never like more work.
Old Nov 4, 2017 | 11:50 AM
Baby99EX's Avatar
that hardrace bushing has things coming out of it where the struts need to go, but the strut needs to bolt there.....
Old Nov 4, 2017 | 06:51 PM
98civdx's Avatar
Master Detailer
The TA bushing does not interfere at all with the shock. It's no where near it.
Old Nov 5, 2017 | 12:06 PM
Baby99EX's Avatar
No, the two little silver wings that r sticking out r where the bolt needs to go......
Old Nov 5, 2017 | 12:47 PM
yes two bolts hold the trailing arm bushing onto the chassis of the car. that metal sleeve is what they bolt to on either side of the bushing.
the strut/shock does not bolt to the trailing arm bushing.. it bolts to the lateral lower arm.. #4 in your picture.
and yes the hardrace brand bushing does have the metal sleeve already in the bushing (trailing arm) where the energy suspension doesn't. That's why I like the hardrace ones, less work!
Old Nov 5, 2017 | 01:08 PM
Baby99EX's Avatar
so where does the lower strut tower bolt go???
Old Nov 5, 2017 | 01:10 PM
Old Nov 5, 2017 | 01:48 PM
civic402lx's Avatar
So, what exactly are you trying to accomplish? You seem to be very confused about your suspension parts.
I suggest you take a photo of what you are working on and post it. Another suggestion, go to youtube and type in "honda civic trailing arm bushing replacement" and watch couple vids. To have a good grasp on what to expect.
Old Nov 5, 2017 | 10:29 PM
Baby99EX's Avatar
This is it.........this bushing.......
Old Nov 6, 2017 | 05:20 AM
oh wow.. that's definitely not what I was describing earlier, that's the rear lower control arm bushing you're showing.
And it's completely missing from your arm. Here's the rear lower control arm bushing from Honda..
52622-SH3-013 / Bush, Rear Shock Absorber (Lower) (Hokushin)
It's about $16 online, or just call up your local dealer and see what they want for it. List price is about $20 each.
I'd recommend the Honda one just because it's cheaper than hardrace, and you probably could get it next day at your local dealer.
How did that ever come off there?
Old Nov 6, 2017 | 05:42 AM
tony_2018's Avatar
Fish Twig
Thats not what you call a strut tower bushing, you should address the rust.
Old Nov 6, 2017 | 06:16 AM
Baby99EX's Avatar
thanks, i ordered a pair.......now, do they need to be pressed in? or can it be done with a clamp...../? thanks u guys.....
Old Nov 6, 2017 | 06:42 AM
civic402lx's Avatar
You need to get it press in. Either by your mechanic or if you chose to do it yourself, you need to rent the ball joint press kit from advance auto or O'Reilly. Clamp and what not will not be strong enough and will deform the bushing. It will not last long if the bushing get deformed.
Old Nov 6, 2017 | 06:45 AM
civic402lx's Avatar
Looking at your picture, the bushing is gone but the outter sleeve that house the rubber bushing is still there. U need to remove that sleeve prior to installing new bushing. Saw the sleeve off or hammer it out with flat screwdriver.
Old Nov 6, 2017 | 07:21 AM
Baby99EX's Avatar
i dont know, but all over the rubber is gone, and i dont see te little metal sleeve anywhere now, its bare......
Old Nov 6, 2017 | 07:54 AM
civic402lx's Avatar
I still see it from the photo. There is a lip on it. If the sleeve is gone then the hole will be smooth throughout. No rough. Perfectly smooth and round.
Old Nov 6, 2017 | 07:55 AM
civic402lx's Avatar
Go here.
https://honda-tech.com/forums/suspen...t-lca-2411953/
Same procedure for your rear lower control arm bushing.
Old Nov 6, 2017 | 01:15 PM
Baby99EX's Avatar
do i need to beat it or what? its all smooth when i rub it w my finger
Old Nov 6, 2017 | 02:29 PM
civic402lx's Avatar
If you are certain its smooth on both side then you are ok to press in the new bushing. It will be a tight fit.
Old Nov 6, 2017 | 05:50 PM
98civdx's Avatar
Master Detailer
that's the LCA bushing. (shock mount)
go to autozone, or whatever, and tell them what bushing you need.
it IS press in, you WILL need to cut/hammer the outer ring of the bushing out.
Old Nov 7, 2017 | 09:04 AM
Baby99EX's Avatar
do all of those bushings have that metal ring??
Old Nov 7, 2017 | 11:09 AM
civic402lx's Avatar
Yes. Oe type/spec does. Look at this picture.
https://www.google.com/search?q=civic+lca+bushing&prmd=sinv&source=lnms&t bm=isch&sa=X&ved=0ahUKEwib_-aVl63XAhUs7oMKHSQUAAMQ_AUIEygC&biw=1280&bih=800#im gdii=yTXqRiaLX8FbOM:&imgrc=Kd9PuPgyhzQYYM:
do you see the silver "ring/sleeve" on the outside? That need to be gone from the control arm before pressing in the new bushing.
labradoofis
Nov 4, 2009 05:58 AM
93formula
Sep 7, 2005 07:49 PM
Honda.F1
May 29, 2004 06:10 PM
001020
Feb 16, 2004 07:44 PM
playAho
Apr 14, 2003 08:16 AM
