99 EX strut tower bushings??
Re: 99 EX strut tower bushings??
Majestic Honda - The Internet's #1 Honda Automotive Parts Store
to name a couple.. just use their website and look up the parts, you can find the part numbers there. Not difficult to do. Good website layouts.
thanks man, but they dont have what i need........
https://dz310nzuyimx0.cloudfront.net...98797ee414.gif
i need the bushing that is right above the bolt on #20, as u can see,its not even a selectable option.....
oh that's the rear trailing arm bushing.. Lots of aftermarket options. I don't think Honda sells that separate from the trailing arm. Even though you can press it out and replace it. Hardrace should have one if you want rubber, and Energy Suspension should have one in polyurethane.
hardrace here's their part number
HARDRACE GLOBAL - REAR TRAILING ARM BUSHING?6115
Energy suspension if you want polyurethane.. Hardrace is rubber.. some like it since it's less vibration..
energysuspension.com | parts search
looking at both I'd probably go with Hardrace if it was me.. The energy suspension doesn't have the mounting part of the bushing.. meh, I never like more work.
the strut/shock does not bolt to the trailing arm bushing.. it bolts to the lateral lower arm.. #4 in your picture.
and yes the hardrace brand bushing does have the metal sleeve already in the bushing (trailing arm) where the energy suspension doesn't. That's why I like the hardrace ones, less work!
So, what exactly are you trying to accomplish? You seem to be very confused about your suspension parts.
I suggest you take a photo of what you are working on and post it. Another suggestion, go to youtube and type in "honda civic trailing arm bushing replacement" and watch couple vids. To have a good grasp on what to expect.
oh wow.. that's definitely not what I was describing earlier, that's the rear lower control arm bushing you're showing.
And it's completely missing from your arm. Here's the rear lower control arm bushing from Honda..
52622-SH3-013 / Bush, Rear Shock Absorber (Lower) (Hokushin)
It's about $16 online, or just call up your local dealer and see what they want for it. List price is about $20 each.
I'd recommend the Honda one just because it's cheaper than hardrace, and you probably could get it next day at your local dealer.
How did that ever come off there?
You need to get it press in. Either by your mechanic or if you chose to do it yourself, you need to rent the ball joint press kit from advance auto or O'Reilly. Clamp and what not will not be strong enough and will deform the bushing. It will not last long if the bushing get deformed.
Looking at your picture, the bushing is gone but the outter sleeve that house the rubber bushing is still there. U need to remove that sleeve prior to installing new bushing. Saw the sleeve off or hammer it out with flat screwdriver.
I still see it from the photo. There is a lip on it. If the sleeve is gone then the hole will be smooth throughout. No rough. Perfectly smooth and round.
that's the LCA bushing. (shock mount)
go to autozone, or whatever, and tell them what bushing you need.
it IS press in, you WILL need to cut/hammer the outer ring of the bushing out.
Yes. Oe type/spec does. Look at this picture.
https://www.google.com/search?q=civic+lca+bushing&prmd=sinv&source=lnms&t bm=isch&sa=X&ved=0ahUKEwib_-aVl63XAhUs7oMKHSQUAAMQ_AUIEygC&biw=1280&bih=800#im gdii=yTXqRiaLX8FbOM:&imgrc=Kd9PuPgyhzQYYM:
do you see the silver "ring/sleeve" on the outside? That need to be gone from the control arm before pressing in the new bushing.
Honda.F1
05-29-2004 06:10 PM
001020
02-16-2004 07:44 PM
