frustrated!! crank no st, new distr,fuel pmp, relay? HELP
Old Nov 3, 2017 | 01:41 PM
dellaccordwag's Avatar
Default frustrated!! crank no st, new distr,fuel pmp, relay? HELP
I tried a new relay, pump, distrib, and ecu! no spark???????
94 accord ex wagon vtech
HELP11111
Old Nov 3, 2017 | 04:13 PM
holmesnmanny's Avatar
Default Re: frustrated!! crank no st, new distr,fuel pmp, relay? HELP
check all the fuses in the engine bay, check that the yellow/black wire going to the distributor has power, make sure the distributor connectors are plugged in fully and not corroded
Old Nov 3, 2017 | 04:41 PM
Did all except for testing the distrib @ the wires u spoke of. but.... i checked the ignition switch with a multi meter and it failed soooooo gonna give it try?!
Old Nov 4, 2017 | 09:48 AM
user456101's Avatar
You could check out a couple of YouTube videos by Schrodinger's Box called the FASSTEC method (stands for Fuel, Air, Spark, Timing at the crank, etc)
DjSeeThrough
Apr 11, 2018 07:14 PM
rnw16
Aug 28, 2016 09:02 PM
Jeremy Harris
21
May 2, 2016 10:58 AM
C-RICKS
Aug 15, 2009 06:05 PM
chazfehn
15
Oct 12, 2008 08:36 PM
