Help! Having sensor issues
Hello guys im pretty shure what i am about to ask is already in some forums on this site already but theirs so many opinions i honestly dont know what to believe ok so i have a 1997 honda civic with a cel light the ob2 is throwing the code p1361 and the description says “camshaft position (cmp) Senaor a (top dead crnter (tdc) intermittent interuption or top dead center sensor (tdc)” help any one?
sounds like a distributor issue. if you replace the whole unit itll most likely solve your problem. or check timing and belt timing(tdc) marks ive seen cases where the belt is slightly stretched
