Water under dash??
So I’ve been hearing water slushing under/behind the dashboard. So when I googled it said the ac drain line could be clogged which I believe to be true cause I never seen it drain. Can somebody point me in the direction of that drain line please
If your car is a 3.0 V6 then look no further than above the passenger sub frame.
Being a V6 car there is a known problem that the AC drain actually causes the front subframe to rot out. If you can, install additional tubing to get the drain to not piddle on the subframe.
darkestfenix
Jun 24, 2010 09:36 PM
