Skunk2 drag launch springs?
Old Nov 11, 2002 | 04:17 PM
Speedfreak's Avatar
Default Skunk2 drag launch springs?
I was wondering if anyone runs them on the street
Does anyone have any experince with them,
[Modified by Speedfreak, 1:18 AM 11/12/2002]
Old Nov 11, 2002 | 04:32 PM
2001TypeR's Avatar
Default Re: Skunk2 drag launch springs? (Speedfreak)
Yeah, i actually would like to know also...i think i want them also....
Old Nov 12, 2002 | 05:53 AM
1fastVX's Avatar
Default Re: Skunk2 drag launch springs? (2001TypeR)
Yeah well they are 900lb springs...what would you expect from 900lb springs on the street...well I have run them on a integra with some Koni yellows and they are a little rough for day to day driving...they are touchy if you try to take a hard turn with some bumps you will lose traction if you are not carefull...it just depends on your personality...as a second option you can buy Skunks setup that includes the standard street rated spring and the 900lb drag spring....then you just swap them when you go to race...then you get the best of both worlds...good luck!
Old Dec 30, 2002 | 12:10 PM
2001TypeR's Avatar
Can you run these springs on stock ITR shocks? I know the ride will be bumpy but would it work or not? Would it be ok for the shocks and struts?
Old Jan 2, 2003 | 05:05 PM
1FsTaxi's Avatar
how much of an improvement would it give you in the 60ft at the track?
Old Jan 2, 2003 | 06:02 PM
XLR8 GS-R's Avatar
Default Re: Skunk2 drag launch springs? (1.5BARtypeR)
why not just go the ghetto way- buy a bunch of hockey pucks, stack them, drill a hole through them and slip them over your strut
Old Jan 3, 2003 | 03:43 PM
2001TypeR's Avatar
Default Re: Skunk2 drag launch springs? (XLR8 GS-R)
Thats a great idea! lol
[Modified by 2001TypeR, 6:43 AM 1/4/2003]
Old Jan 3, 2003 | 09:37 PM
Toad's Avatar
skunk2.com says the increase is 0.03
Old Jan 3, 2003 | 11:29 PM
Suprdave's Avatar
Default Re: Skunk2 drag launch springs? (Toad)
You mean .3 off the 60ft, which can be between .3-.6 off at the lights...
Well worth it IMHO. I will be purchasing a set, cus I'm on a budget.
Suprdave
Old Jan 4, 2003 | 03:56 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Skunk2 drag launch springs? (Suprdave)
I run the drag launch kit on the street. the ride is a bit rough but thats the price you pay for really good traction. they dont bounce like cheap coilovers they just jump once when you hit the bump and are super stiff.
Old Jan 4, 2003 | 07:09 AM
Suprdave's Avatar
Default Re: Skunk2 drag launch springs? (MotorMatrix.com)
Which Shocks are you running with these springs, if you don't mind me asking.
If a 900lb spring was being used on a road-race car...most definately...they would be recommending some kind of Shortened, Revalved Koni by TrueChoice, etc.
I think that would be Ideal, but not needed on a Street\Strip Car. I will just swap back my H&R Race Springs if I take it to a HPDE
Suprdave
Old Jan 6, 2003 | 08:46 AM
I am a bad person
I run kyb agx 8 way adjustable shocks.
Old May 14, 2003 | 10:20 AM
MugenGTR's Avatar
900lbs seems pretty extreme, does the shocks even have an effect when running that high of a spring rate? especially on a car that the rear is all gutted?
Old May 14, 2003 | 10:28 AM
Suprdave's Avatar
Default Re: Skunk2 drag launch springs? (MugenGTR)
Nope...not really...Similar to a solid rear I guess.
Suprdave
Old May 14, 2003 | 06:11 PM
Boostfed's Avatar
New User
I run the Skunk2 Drag Launch rear springs, I used to have 400 lb/in rear Skunk2 in the back with stock shocks and then installed these with the KYB AGX 8 ways at the softest setting and I have to admit they actually are more tolerable than the 400 lb/in with the stock shocks, when you hit a bump your passenger will hate it but I didn't think they were as bad as I expected I'll let you know also when I stiffen the shocks in the rear too
Old May 14, 2003 | 06:31 PM
Luke J's Avatar
Default Re: Skunk2 drag launch springs? (Boostfed)
900lb spring rate has got to be VERY ruff. I have 600's in the rear of my gutted crx and it rides like ****. I have GC coilovers and koni red's that are set on the stiff setting.
Old May 14, 2003 | 06:46 PM
lsvtecvx's Avatar
Default Re: Skunk2 drag launch springs? (Lucky925l)
do these come in pairs just for the rear, anyone on here sell em or know a place that has em for a good price.
Old May 15, 2003 | 02:47 AM
ITRfaithful's Avatar
they're worth it for race cars
Old May 18, 2003 | 04:43 PM
turbospool's Avatar
Default Re: Skunk2 drag launch springs? (iloveintegras)
did anybody have before and after times for the drag springs? woudl these cause any frame damage if ran on the street?
Old May 19, 2003 | 04:17 AM
1 2 NV's Avatar
i dont think my experience with them will help much. alot of factors come into play in my situation. i got my skunk2 coils this yr and went from a best low 1.8 60' down to mid 1.6 60s. also from that 1.8 i was gettin i was launching pretty easy at 6000 or so. the car weighed around 2000lbs w/o me in it. now my car is down to around 1700 minus me and i launch at 8000 or so. on the street they suck. light *** car with heavy duty springs=bone jarring ride.
Old May 22, 2003 | 03:18 PM
lsvtecvx's Avatar
Default Re: Skunk2 drag launch springs? (hondaatwsu)
anyone know where I can get a pair, just foir the rear
Old May 22, 2003 | 03:59 PM
xJ.SLOTHx's Avatar
Default Re: Skunk2 drag launch springs? (lsvtecvx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecvx &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where I can get a pair, just foir the rear</TD></TR></TABLE>
check my sig
Old May 22, 2003 | 04:12 PM
Supernatural's Avatar
i drove around with them for like a year because i wsa too lazy to switch them all the time.....make sure you dont drive too fast on the freeway becuase you might get loose. for the most part it aint that bad if you can stand it. if you got sensitive kidneys then i wouldnt suggest it
Old May 22, 2003 | 07:25 PM
b19coupe's Avatar
Do the Skunk2 drag launch springs fit on the stock perches?
Old May 22, 2003 | 11:24 PM
K20  EG's Avatar
Default Re: Skunk2 drag launch springs? (b19coupe)
yes ...i daily drive the skunk drag launch springs and i think there great ..a lil bumpy...nothin adjustable shocks cant iron out a bit
yes they do fit on stock perches
i wouldnt recomend them if you have back problems or a child on the way
