Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission solenoid inquiry: 98 accord v6
Old Oct 27, 2017 | 01:54 PM
Doug Lamboy's Avatar
Default Transmission solenoid inquiry: 98 accord v6
Hey guys and girls, my name is dougie i have a 98 accord v6 i changed the shift solenoids a,b now tranny is shifting weird before it was shifting hard on first gear only. Do i need to drive for a whike so.it gets accumulated?
Old Oct 28, 2017 | 04:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Transmission solenoid inquiry: 98 accord v6
Define weird.
These transmissions can have some issues, but mileage/maintenance have quite a bit to do with it as well.
Why did you change the shift solenoids?
Have you checked for any stored codes? Not all codes will set off the CEL or D4 light, especially in the 98-02 Accords.
Old Oct 28, 2017 | 04:53 PM
Originally Posted by MAD_MIKE
Define weird.
At first a/tranny was shifting hard from first to second. So i read that shift selonoid can be issue, tested selonoid for.ohms and ohms was all over the place. So i replaced selonoid now shifting is good its a jerk stopping at light or stopping and then a slight hesitating a was accerlating
Old Oct 28, 2017 | 04:55 PM
MAD_MIKE's Avatar
MM Gruppe B
Have you verified fluid level is correct?
Old Oct 28, 2017 | 04:57 PM
Yes changed fliud, no codes, no d4 light flashing, imma take to tranny specialist for disgnosis
Kylegnewman1005
May 27, 2017 10:50 AM
justseeingifitistaken
Dec 16, 2007 07:13 PM
species482
Sep 14, 2007 11:58 AM
gsR_Ace20
May 20, 2007 11:07 PM
