How cheap can I do a K swap?
Old Oct 26, 2017 | 12:05 PM
Vtec04's Avatar
Default Dirt cheap K swap?
I would really like to K swap my 05 Civic, but I can't spend much on it. I don't mind working harder than necessary to do the swap if I can save money. For example, I will happily rewire the C101 connector to save the $200 for a conversion harness. A local self service junkyard has great prices on parts. I don't need power steering, exhaust system, or any extras like that right now. I don't care about minor details like the engine light being on and stuff like that. Here's a short list of major parts that I can think of quickly that I would need:
Engine- $160 flat rate on all complete engines
Transmission- $80
ECU- $23
Subframe with motor mounts- $40
Pedal assembly- $20
Clutch master cylinder- $17
Different CV axles- $20 for both
At $380, this swap may be doable if I save up for a year or so. But there must be hidden charges somewhere. What I need to know is what those hidden charges are, and how much it would cost. Thanks.
Old Oct 26, 2017 | 05:19 PM
pogeeboy27's Avatar
Default Re: How cheap can I do a K swap?
If it takes you a year to save up $380, you shouldn't be doing any car mods at all, especially if this is your first time doing a swap. There will be things you miss or you may screw up on something that requires you to buy more parts.
Old Oct 26, 2017 | 05:27 PM
Vtec04's Avatar
I've changed engines before, but always with the same kind that came out. I guess a lot of you guys are rich or something, $380 is a LOT of money to me.
Old Oct 27, 2017 | 01:51 PM
pogeeboy27's Avatar
If it's one thing I've learned throughout the years modding cars is not cheap, especially if you want to do it right. Also where are you able to get prices like that for engines and transmissions? Those are crack head prices.
Old Oct 27, 2017 | 02:14 PM
Vtec04's Avatar
My local U pull it junkyard has flat rate pricing on every engine and transmission, if I can find one.
Old Oct 27, 2017 | 10:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This means that you will have to be very patient and make a trip every morning to your local U-pull-it junkyard to check their inventory so that you get first dibs on anything really good. RSX's and EP3 Hatchbacks are not common junkyard finds... and this is what you need for your 7G chassis. To do the swap correctly, there are many things that you left out. However, since you stated above that you really aren't interested in doing it right... I am not sure what to put on your list.
For sure... clutch, flywheel, EP3 radiator w/ upper and lower radiator hoses and cooling fan assembly.
You also forgot the expensive stuff that you won't find at the junkyard... a MOUNT KIT.
Good Luck.
Old Oct 28, 2017 | 05:57 AM
1999 Civic Si's Avatar
I helped a buddy k swap his 05 civic coupe and even with him having a 100% complete parts car (ep3) he still spent a couple grand on the swap not including the car(s), of course some of that money was spent on maintenance related things, exhaust work, etc... There are things that you aren't going to find or be able to use from a car out in the yard. I would suggest researching online for k swapping the EM2 chassis to get a better idea of what you are really going to need to do the swap.
Old Oct 29, 2017 | 07:48 AM
Vtec04's Avatar
Good Luck.
I never specified a K20. A K24A1 CR-V motor or K24A4 Accord motor would be very easy to find at a junkyard and would still make good power. I could put a K24A2 head on it later also.
Old Oct 29, 2017 | 02:13 PM
Klasse's Avatar
I don't want to be judgmental but I'm going to be anyway. I really think if it takes you a year to save $380 you shouldn't spend $380 unnecessarily on a car.
Old Oct 29, 2017 | 04:47 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You can barely save 31.66 per month?
​​​​​A swap is not in your budget. That 31.66 should be put towards maintaining the current engine.
Old Oct 29, 2017 | 05:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I didn't state a specific engine... you assumed this because of the chassis choices that I recommended. Regardless, the engine choice is of little concern. It is the transmission and supporting components of these two applications that ARE important. You must do a large amount of research in order to collect the PROPER parts for your application... getting the wrong parts will cost you more money in the long run, and since you seem to be really short on cash, you cannot afford to make a bad choice.
Old Oct 29, 2017 | 08:33 PM
Vtec04's Avatar
You're unfortunately probably right. Now I think I have a blown head gasket because someone drained my coolant in the middle of the night, and the engine overheated. I won't be able to afford a $40 head gasket for about a month, so I definitely am broke.
Old Oct 29, 2017 | 09:10 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Maybe you're car overheated when you towed that trailer
Old Oct 29, 2017 | 09:55 PM
Vtec04's Avatar
The temp never exceeded 200 while pulling the trailer.
Old Oct 30, 2017 | 03:09 AM
Chance EG's Avatar
Jesus christ dude get a (better?) job and/or get your expenses under control.
Why were you even asking about K swaps in the first place? You're absolutely high if you think you can afford this right now, regardless of how many options you omit and how much DIY is performed.
Old Oct 30, 2017 | 08:31 AM
NVturbo's Avatar
O.G. triple O.G.
Agreed with you guys. If you can't afford to mod your cars, leave the **** alone. Just look at all those cars on Craigslist, half-assed and incomplete. They think it's going to be fun and cheap and eventually, they don't even have money to replace a $25 part.
Old Oct 30, 2017 | 12:18 PM
greenwitenvydc2's Avatar
I am 100% sure some of my brain cells just died reading this post. I've almost completed my K SWAP and its taken me some time buying used parts and finding deals and I am still almost 2k into it. I have an accord K24 and EP3 trans and that was 900.
1992HondaCivic
22
Jul 6, 2009 09:04 AM
B18C5-EH2
Dec 5, 2007 05:54 AM
tltas0325
Apr 13, 2004 08:21 PM
deviant1
Jan 27, 2003 06:26 AM
seineil
May 19, 2002 01:13 PM
