Need help 2001 Honda Accord lx turn signals stopped working but hazards still work
So I’ve changed turn signal switch & flashers relay as well too both relay & turn signal switch work in my other accord so they are still good.. So what else could be the problem and how can I fix it pls someone help me out
let's do it the easy way, take a relay that looks similar and swap it for it, there are numerous relays that work the same way
Pull the hazard switch. With the switch in the off position check the continuity between the #1 and #2 pins of the switch.
If you will follow the diagram and my "simple" explanation....in the "off" position power from the drivers #10 7.5 amp fuse - you were asked and stated it is good - "flows" from the #1 pin to the #2 pin and finally to the relay. In the "on" position you can see power flows from the underhood fuse via the #3 pin to the #2 pin and to the relay. So if there is "poor" connection inside the switch from the #1 to the #2 the relay is never getting the power it needs.
Again, I'm trying to keep this simple so don't "rag" me about using "pin" vs wire or whatever.
Also note the 98-00 have different numbering/configuration than the 01-02
