93 Integra Fuel pump Won't turn on with new pgm-fi relay
Old Oct 25, 2017 | 11:27 AM
tangiblestar's Avatar
Default 93 Integra Fuel pump Won't turn on with new pgm-fi relay
I'm working on a 1993 Integra hatch with a B18a1 and manual transmission that has an intermittent crank but no start. It went from starting and running fine to taking a few seconds extra to start, then cranking but not starting. Since it was time for a new fuel filter, I replaced that and since I have had pgm-fi relays test well but still fail, I replaced that. The car fired right up after priming the fuel filter. A few minutes later, it would not start. If I jump the pgm-fi plug from ignition power to the fuel pump, the pump runs but if I put in the relay, the pump will not run. It doesn't even do the 2 second prime. I have the factory service manual and I followed the flow chart up until needing a ecu breakout tool that costs about $2000 now. The only odd thing during the test was one pin in the pgm-fi relay plug should have battery voltage while cranking but it only showed about 10.5 volts.
Old Oct 25, 2017 | 04:48 PM
tamboo's Avatar
10 Year Member
Default Re: 93 Integra Fuel pump Won't turn on with new pgm-fi relay
is it a mitsuba main relay? did you try a solder reflow?
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
i'd swap ecu if that dont work.
Old Oct 25, 2017 | 05:00 PM
I replaced the factory relay with a brand new one. The original relay actually tested fine according to the FSM test procedure. I ordered an ECU but I hate throwing parts at a problem instead of actually diagnosing it.
Old Oct 27, 2017 | 03:57 PM
tamboo's Avatar
10 Year Member
well if the ecu is actually good you'd have a spare to send off to phearable or whomever.
then when it comes back you can sell the other on fleabay.
Old Oct 29, 2017 | 07:59 AM
Got a reman ECU from HAmotorspots and the car runs fine now!
Old Oct 29, 2017 | 04:33 PM
tamboo's Avatar
10 Year Member
congrats! 8)
EJ8CIVIC
Jul 7, 2015 03:47 AM
muellteam
Jan 16, 2009 06:51 AM
PatrickFrantz
Jul 17, 2008 11:37 AM
uszcrx
24
Sep 9, 2006 01:05 PM
ROK801
Oct 31, 2005 07:28 AM
