Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Slave Cylinder Mount Broken!!!
Old Oct 23, 2017 | 09:16 AM
Craig Duni's Avatar
Default Slave Cylinder Mount Broken!!!
Hello All,
The slave cylinder mount broke on my 01 Civic, see picture beloe, any suggestions on how to fix this. I was thinking like JB weld or having someone tack weld it. Any ideas?
Thank you
Old Oct 23, 2017 | 09:00 PM
toyomatt84's Avatar
Sanji
Default Re: Slave Cylinder Mount Broken!!!
JB Weld won't last long, if at all. I would see if you could get someone to TIG weld and possibly drill/machine it for you.
Old Oct 24, 2017 | 04:48 PM
utn's Avatar
utn
Since you still have one bolt which I assume is undamaged, you could drill and tap a new (probably smaller) hole through the slave cylinder and into the bell housing with a new bolt, somewhere in-between the two original bolt holes. That's probably what I would consider for a non-permanent mounting. If you meant by JB Weld/TIG welding it in place forever.
Old Oct 24, 2017 | 04:55 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
If you have the time, take out the transmission and have that broken hole rebuilt, filled, and redrilled+tapped.
killa31
Sep 11, 2018 09:15 AM
Baten619
Sep 1, 2010 07:13 AM
Balwin
Jun 23, 2010 08:48 PM
snzh22
Apr 28, 2008 05:13 AM
Speed Kills
Jun 30, 2006 06:10 AM
