'97 Civic DX with D16Z6 Swap Shifting Issue
Old Oct 21, 2017 | 10:26 PM
Cozmikk's Avatar
Default '97 Civic DX with D16Z6 Swap Shifting Issue
I have an issue with shifting on my Civic. I just finished the swap and and all the wiring checked out fine. When I started the car it ran perfectly. I got all of the coolant in that was needed and the oil amount is correct.
When I did the swap, the transmission was the only part of the car that had parts swapped around. The z6 transmission that came with the z6 engine was a lever clutch and the DX uses hydraulic so I needed to use the stock tranny that came with my d16y7. They are both d-series engines and from what I had read online, all of the components should be interchangeable. Long story short, I am running:
D16z6 with a y7 tranny
y7 tranny has new clutch and pressure plate. Because of difference in the splines between the y7 and z6 tranny, I am using the flywheel from the z6 as the y7 one is not compatible (difference in splines).
After the car was together, I started the car and shifted into 1st gear. I made it about halfway down my driveway. I think I made it into 2nd gear but then I stopped to be sure there was no other traffic the road I was turning onto. After I stopped, I put the car in neutral. It now appears to be stuck in neutral. I can hear the shift linkage move the selector but it doesn't appear to actually catch a gear. I have looked at the slave cylinder and it moves when the clutch is pressed. The car just doesn't catch any gears. I can a faint grind into reverse which is usual if I am remembering right. Like I said, the clutch is new. When I put it all back together, I made sure to do absolutely everything correctly inside the tranny (bolt torques and everything) to be sure there were no mistakes.
Hope someone can help me with this,
Thanks!
hatche1
Transmission & Drivetrain
19
Nov 27, 2010 11:19 AM
SEATownboi08
Feb 20, 2008 07:09 PM
1989rexsi
Aug 12, 2007 07:51 PM
Moon Ill
Jul 17, 2005 06:33 PM
Daisysi
Jan 29, 2004 06:01 AM
