EF Strut tower extensions
Hey Down Star Inc. makes strut tower extensions but not for EF. Anyone know who makes these for an EF? My upper A arms are hitting the top of the strut tower. Seriously lowered Race car.
Here is my setup now:
Shortened Koni race shocks
Ground control race coil overs
400lb front springs
600lb rear springs
No front sway bar
stock SI rear bar
shaved bump stops
Skunk2 adjustable upper A arms
all eurothan bushings
extended ball joints Hard Race
Hard Race Tie Rod ends (up side down style)
400lb front springs
600lb rear springs
No front sway bar
stock SI rear bar
shaved bump stops
they dont
but if you word the question in a way that makes it seem more legit
you can hide the fact that your just driving around in a slammed car bottoming out everywhere
and you still want to go lower
extend the strut mounting points = even lower car about a 1/4 inch off the ground
400lb front springs
600lb rear springs
No front sway bar
stock SI rear bar
shaved bump stops
400lb front springs
600lb rear springs
No front sway bar
stock SI rear bar
shaved bump stops
I’ve seen it done. Pictures should be online somewhere. It’s easier to get the right suspension set-up instead of cutting up the car. Check out H&R Ultra Low Coil-Over Set
Vovchandr
Feb 24, 2008 05:39 PM
ExplicitSpeed360
13
Dec 15, 2005 09:13 PM
