I finally got my honda !
(Intro) Okay so I made a post few months back asking what kind of civic I should get and what kind of swap I should do.
heres what I got and my plans for it !
(the car itself)
I picked up a 95 EG coupe (not exactly what I wanted ) but I'm happy with it .
it has a stock d serious which I did NOT want .. with 257 k original miles .. so clearly if going to get a swap sometime soon.
(the plans)
turbo the d until it blows , then swap it for B or K depending on what I find. First things first I am removing the rust from the hood and fender because previous owner thought it was cool to rust it on purpose . So going to sand in 3 different gritts then primer then repaint , the whole car is getting body work like bondo, primer , paint .
(the cons)
257k on d serious, stock exhaust/muffler , body is rough , front end does not line up, hood don't close .. it was in an accident in the front and also trunk does not line up 100% but still closes. 5% tint which is not legal but **** it . Has camber so needs new tires.
follow the build on Instagram : dj27nitro
give me ideas and also somebody let me know what my EG is called like eg1 , eg2 , EG 3 ?! Ej2?
If you want to know what chassis car you have, look at the VIN number.
The 4th, 5th, and 6th octet's refer to the chassis code. So, its more than likely an EJ1 not an EG.
crxsi361
12
Nov 27, 2010 07:39 AM
EG93si
16
Oct 29, 2005 09:45 AM
EG6FF
Feb 11, 2004 05:24 PM
