Car not starting after installing hondata 4 bar map sensor
Old Oct 14, 2017 | 01:31 PM
Todallybuilt's Avatar
Default Car not starting after installing hondata 4 bar map sensor
Help Guys,
After I installed hondata 4 bar map sensor my car does not want to start. I have selected Hondata 4 bar map sensor inside the hondata software, I have also try changing the settings back to stock map sensor and it still does not turn on. When I plug the stock map sensor it turns on without any problems. The hondata map sensor is brand new. Can you guys please help me out? Thanks I appreciate any help
Old Oct 29, 2017 | 06:05 AM
GhostAccord's Avatar
Default Re: Car not starting after installing hondata 4 bar map sensor
Can you see any signal output from the sensor in your SManager datalog? Have you tried testing the sensor? Wouldn't be the first time a sensor was bad right out of the box.
Todallybuilt
Engine Management and Tuning
Oct 15, 2017 06:18 AM
b20turbocivic
Aug 12, 2010 07:06 PM
boostjunkieee
Aug 9, 2008 08:43 PM
lucidvtec
Jul 11, 2005 11:51 PM
