Engine head disassembled, Timing ok?
Old Oct 14, 2017 | 12:03 PM
Malt-liquor's Avatar
Default Engine head disassembled, Timing ok?
I pulled apart my engine cylinder head to pull the valves and such and get the head resurfaced for head gasket replacement. So I read that TDC on the engine block is when the piston on cylinder 1 is all the way up correct? Now I pulled my camshaft and do I just face the arrow up when I reassemble everything, would this be TDC? This is first time I pulled apart a cylinder head before. I did mark the cam gear with the timing belt when I pulled it, but it wasn't TDC. Can someone please explain how this works?
Old Oct 14, 2017 | 07:24 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Engine head disassembled, Timing ok?
I don't think that's how the Porsche boxter motor works.... But I could be wrong.
Old Oct 15, 2017 | 05:14 AM
Sorry about that, 95' Civic LX automatic D15B7
Old Oct 15, 2017 | 06:44 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good deal, Piston 1 would be at the top, but also you can check the crank gear. It has a mark on it that will line up with the arrow on the block for TDC.
Then for the head, you have the cam gear "up" sitting at the top and the left and right hash marks on the cam gear will be level with the top of the head. The head is then in TDC position.
Old Oct 15, 2017 | 08:27 AM
Sweet easier than I thought, are the other gears OK to be wherever?
Old Oct 15, 2017 | 09:02 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
What do you mean? You only have the water pump which is a symmetrical unit so any position is the same as the next and the tensioner pulley.
TDC only has to do with setting mechanical timing for the timing belt.
Old Oct 15, 2017 | 09:30 AM
Right, should I put the distributor back on in the mid to adjust if needed? I have the whole head taken apart right now. Thanks
Old Oct 15, 2017 | 09:35 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
First focus on getting the head on and timing belt.
After that is done, you can study the distributor and the tangs, they are slightly off set and you will want to match them up to the tang holes on the cam shaft. It can be put on 180* out but not easily because of the offset. Lets not let you do that by advising you should inspect it closely to observe the offset.
It's best to not have the distributor connected to the head when doing a head install. You deal with that part after you get done with the timing belt.
Old Oct 15, 2017 | 10:03 AM
tony_2018's Avatar
Fish Twig
distributor is not needed to do the timing belt alignment.
Old Oct 15, 2017 | 12:32 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
LoL, I need you as my editor. Feel like I am too wordy like Steven King and you come in and put my whole 3 paragraph post into a 10 word sentence.
Old Oct 15, 2017 | 04:42 PM
tony_2018's Avatar
Fish Twig
been noticing members just want str8 answers dude, they care not for explanations like in the past.
Yooyenkoo
Dec 2, 2010 10:20 AM
thavarin
Sep 9, 2008 05:55 AM
Dublin
May 12, 2006 08:47 PM
Power Rev Racing
Jul 1, 2005 09:50 AM
USDMMARK
Oct 10, 2003 04:01 PM
