Header glow red from timing- D-series. Suggestions?
Old Oct 13, 2017 | 09:27 PM
Akeem Willis's Avatar
Default Header glow red from timing- D-series. Suggestions?
I have a 89crx si with z6 swap p29 high comp pistons skunk2 manny arp head studs king race bearings and high flow oil pump when I start the car header glow red after only two mins running and I can't figure it out any help would be great
Old Oct 13, 2017 | 10:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Header glow red from timing- D-series. Suggestions?
It is either really lean or the ignition timing is really retarded.
Old Oct 15, 2017 | 02:18 PM
Default Re: Header glow red from timing- D-series. Suggestions?
Am running a aem fpr with that setup too
Old Oct 17, 2017 | 11:56 AM
TheShodan's Avatar
Moderator
Doesn't change what JRCivic1 stated.
Old Oct 18, 2017 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
In rare cases, running really RICH allows unburned fuel to ignite in the header... and will also cause the header to glow red. This is the least likely cause of your problem... so check your ignition timing and then get the car to a dyno and tune it.
1990civicdx
Jul 15, 2018 12:57 AM
slobalt716
May 2, 2014 08:43 AM
jinx_fx
10
Jan 30, 2014 02:02 PM
dschenke
20
Dec 31, 2008 08:08 AM
teg_racer
Dec 8, 2007 05:12 PM
