can somebody provide me with a basemap for THIS specific B16A2 Build Please?
Old Oct 10, 2017 | 06:36 AM
crookson speed's Avatar
Default can somebody provide me with a basemap for THIS specific B16A2 Build Please?
i have a b16a build
81.5
supertech flat valves
less then 10 thou off the head and block
stock pistons
slightly ported head
stock everywhere else
i was wondering if andybody could give /sell me a base map for crome as i dont think i have any tuners near me in santa barbara so id like to drive to one safely. id also like to break in my car safely and get it smoged. thanks and if not im looking for sme crome specific guides on how to adjust fuel tables. not just idle and post start up with fuel tools. i know im a noob but thanks guys.
Old Oct 10, 2017 | 07:35 AM
2x0's Avatar
2x0
10 Year Member
Default Re: can somebody provide me with a basemap for THIS specific B16A2 Build Please?
If I'm not missing something, this should start up and run fine on a stock b16 tune. Of course it will need changes to the fuel and ignition tables to run optimally, but for getting it to a tuner it should work...
Usually a basemap is only adjusting for different injectors, map sensor, fuel type or pressure but that's it until you start tuning. You didnt mention any of those variables.
Old Oct 10, 2017 | 07:05 PM
thanks im just trying to keep this expensive investment together.
Old Oct 10, 2017 | 07:43 PM
theYBLEGAL's Avatar
Loved
You are for sure fine on a stock tune. Enjoy!
Old Oct 11, 2017 | 07:07 AM
spAdam's Avatar
Loved
Community Favorite
You could pull a degree out of the WOT line (the two highest load columns) for a little extra safety during break in, but otherwise I agree with the other guys. Just run a stock B16 map.
Old Oct 15, 2017 | 03:44 PM
what about messing with fuel tools and adjusting the multiplier up a little also i messed with the iacv idle settings bumped up the lowest rpm by 25 because of a lightened flywheel and n1 crank pulley
Old Oct 15, 2017 | 03:46 PM
and also by b16a2 build i ment jdm b16 with p30 pistons
Old Oct 15, 2017 | 04:02 PM
i pulled back the timming in the last 2 collums the highest number is 24.75 degrees safe???
Old Oct 16, 2017 | 06:50 AM
spAdam's Avatar
Loved
Community Favorite
That should be plenty of timing to get you to your tuner safely.
Old Oct 17, 2017 | 05:33 AM
the two highest collums on the high cam right
Old Oct 17, 2017 | 07:43 AM
spAdam's Avatar
Loved
Community Favorite
Low cam too.
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
raverx3m
Sep 30, 2013 07:04 PM
BTU333
Jul 10, 2013 03:41 PM
sleepyhatch00
Sep 15, 2005 06:27 PM
keebler65
Jul 6, 2003 07:27 PM
