91 accord sometimes wont restart after setting for a few mins.
Old Oct 6, 2017 | 10:45 AM
overunderhood's Avatar
Default 91 accord sometimes wont restart after setting for a few mins.
After running for a short while, or short distance the car won’t restart. It turns over, momentarily starts (1sec) then peeters out. Then it can take up to 15 mins to get it to start again. I wait until the check engine light extinguishes then try it. Sometimes when the light extinguishes I don't hear the click. No codes registered.
Old Oct 6, 2017 | 04:02 PM
holmesnmanny's Avatar
Default Re: 91 accord sometimes wont restart after setting for a few mins.
when it's not starting, immediately check for fuel and spark
Old Jan 17, 2018 | 11:42 AM
How do I do that, especially by myself?
Old Jan 17, 2018 | 12:21 PM
turn the key to on without starting the car and immediately turn it off, using a ratchet and a 17mm socket, unscrew the bolt on top of the fuel rail where the line from the fuel filter comes in and see if fuel sprays out while having a rag around the bolt to help catch fuel
Old Jan 17, 2018 | 06:28 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You mentioned the Check Engine Light staying on. As stated in this link, the Check Engine Light should go on then off, if it stays on or stays off then the there won't be any spark on most models.
https://web.archive.org/web/20170605.../mainrelay.htm
One of the possible cause is a bad main relay.
Old May 17, 2018 | 06:26 AM
Found the fix to my own problem.....it was merely a bad vacuum hose end....I cut 1/2 inch off of the end and use a tie-wrap to secure on connector....drove it now for two weeks without problem reoccurring.
ak768
Feb 8, 2019 12:38 PM
Felipe_Rdz
May 8, 2013 02:27 PM
bayoufox
Apr 16, 2013 05:04 AM
fsjeep
Jun 28, 2009 03:10 PM
92awd4u
Sep 27, 2004 09:23 PM
