ECM/ECU question
Old Oct 5, 2017 | 06:05 PM
erndog's Avatar
Default ECM/ECU question
If I were to replace a 37820-P28-A02 with another 37820-P28-A02 ECM, would I need to have it "reprogrammed" or can I continue on?
Old Oct 5, 2017 | 06:36 PM
civic402lx's Avatar
Default Re: ECM/ECU question
Continue on.
Old Oct 6, 2017 | 03:12 AM
erndog's Avatar
My current issue that seems to boil down to the ECM is this. I am getting no signal pulsing to my #3 injector. It has the 12v signal, but evidently not the pulsing ground. If I swap the leads with the #4 injector, the #3 injector works fine, so it is not an injector problem. I have tested continuity back to the C101/C206 connector and it is fine. There is a chance that the wire is broken between there and the ECM, but I doubt it. I also suspect the ECM because besides the #3 injector issue the engine stutters violently (read whaaka, whaaka, whaaka) at 3,500 rpm, regardless of speed, gear, etc. It also used to stutter occasionally in first gear prior to the injector issue.
So, my new question is this. While I wait for a new ECM can I cross-connect the #3 and #4 injector wires so my engine doesn't miss so badly (I need to drive it to work and back daily)? I was amazed that while doing my little injector test it ran well (obviously still only on three cylinders) with the #4 wire going to the #3 injector! As near as I can tell, #3 is on the compression stroke while #4 is on its intake stroke. I feel injecting into #3 during the compression stroke would not be all that bad of a thing. It would just make it into a bit of a two-stroke cylinder vs four-stroke.
Any thoughts on this?
Old Oct 6, 2017 | 04:44 AM
mk378's Avatar
Connecting two injectors in parallel would overload the injector driver, it is designed and calibrated to drive only one. Running on 3 cylinders is going to shake stuff to death, park the car until you make proper repairs.
Old Oct 6, 2017 | 12:36 PM
erndog's Avatar
This may be part of the problem, if not all.
Old Oct 7, 2017 | 03:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Looks like rodent damage.
Old Oct 7, 2017 | 03:38 PM
mk378's Avatar
Yes, rodents.
I think you can unplug the plugs under the hood then pull the harness through the firewall to the inside of the car making it easier to reach the damaged area. Splice the wires and tape it up.
Old Oct 10, 2017 | 11:51 AM
erndog's Avatar
I repaired this damage and the car runs like new now! I was minutes away from ordering a new ECM, too. I also found 16 partially chewed nuts under the battery tray adjacent to the wires.
Old Oct 10, 2017 | 12:37 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Dese nutz...
Old Oct 10, 2017 | 07:16 PM
Vector 25's Avatar
yea it was never the ecu good job fixing it thou
Old Mar 26, 2018 | 09:37 AM
BadCompany300's Avatar
replacing my ecm as well and was just wondering what all I have to do before plugging in my new ecm
mickey b16
May 18, 2009 07:33 PM
hyper em1
Jan 31, 2007 09:46 PM
Coldsi
Jun 19, 2002 09:32 PM
