Bosch 2200cc Feedback needed
Old Oct 5, 2017 | 04:31 PM
Berto24's Avatar
Default Bosch 2200cc Feedback needed
As the title says, looking for anyone running this injectors part number 280 158 821
Old Oct 5, 2017 | 05:36 PM
hpmx18's Avatar
Default Re: Bosch 2200cc Feedback needed
what are you trying to figure out
Old Oct 5, 2017 | 05:43 PM
Berto24's Avatar
they are big injectors just what i need to run e85, and they relatively cheap. Wondering if they work well
Old Oct 5, 2017 | 06:02 PM
hpmx18's Avatar
since i used them never had an issue just make sure you have right size filters in your sytem to keep them clean and you should be good
Old Oct 6, 2017 | 08:02 AM
Pumpking.'s Avatar
double & triple check them if you aren't buying FID, FIC, ID, Grams, etc.
Tons of Bosch 2200 chinese knock-offs out there now for 'cheap'.
Old Nov 30, 2017 | 04:09 PM
b20ricepower's Avatar
I've ran them with good success. Haven't even went past 70% duty cycle yet but so far so good. Idles well. The only issue I have is with the pre injector filters clogging up with gunk from the e85. If you plan on letting the car sit for an extended period, I would pickle the fuel system with 93.
Old Nov 30, 2017 | 10:35 PM
CHB's Avatar
CHB
70% duty cycles on E85?
Boosted?
Old Dec 1, 2017 | 06:27 AM
rudebwoy's Avatar
Everything You Never Wanted to Know About Alcohol - Injector Dynamics
Old Dec 1, 2017 | 06:30 AM
rudebwoy's Avatar
I use ID2000 injectors, and follow the procedures of keeping them alive, I've also sent them back a few times to get cleaned. Now that E85 is no longer sold in Germany I'm considering Using VP race fuels which is available, I read that they are not compatible with VP fuels, which injectors are people using with race gas?
Old Dec 1, 2017 | 10:47 AM
Chef Andre's Avatar
HT's TOP CHEF
In for info
Old Dec 3, 2017 | 11:31 AM
SPOOLINmatt's Avatar
the 2200's arent compatible with VP Import, Q16, and C85. Others as well. They work it just shrinks the flow rate when you use their fuels like those that contain MTBE.
Old Dec 5, 2017 | 11:50 AM
Chef Andre's Avatar
HT's TOP CHEF
So can anyone give me some tips on how to tell if they're authentic? I found a great deal locally but I noticed online that there are some fakes out there.
Old Dec 8, 2017 | 04:42 PM
miahjera04's Avatar
Just buy new ID,FIC,FID 2200s... run a legit filter too. I use the F750 from ID... bad bitch
Old Jul 31, 2019 | 03:26 PM
Ckirk's Avatar
Was wondering if you would share you map. Trying to compare to get my idle improved. Thanks
bcintron95
Aug 13, 2016 12:20 PM
Tuner Eddy
Jul 24, 2013 05:26 PM
vtec8200
Apr 30, 2012 07:09 PM
xstalkrx
Jul 3, 2004 03:10 PM
99B16Si
Dec 16, 2003 07:53 AM
