New clutch for '96 Integra won't engage
So I installed a new clutch and new Luk flywheel in my '96 RS Integra (Exedy OEM package). It came with the disc, pressure plate, pilot and throw out bearing. I followed the HELMS manual to a t and got tips from other install write-ups. Flywheel dowels fit right into PP, I used the clutch alignment tool, high temp grease where it should go, and everything else but when I went to drive the car it's as if the clutch pedal is always pushed in even when it's not. I DID bleed the hydraulics and adjusted the pedal. I can change gears with the engine on and the clutch pedal all the way out, and yes the shift-linkage is connected and changing gears. Any idea what it might be? I've read a few times that people who had this issue didn't have their passenger side axle all the way in and that's what caused it. how would I tell if it was not seated properly? I'm not very familiar with the differential (non-LSD) and it's behaviors such as if the car was jacked up would both wheels spin if I spun one by hand? Or is it possible to install the throw out bearing backwards?
My passenger side axle wasn't pressed in all the way (slap on wrist) so my clutch actually was working but I just wasn't getting any power to the wheels.
supadupafast
May 16, 2015 06:47 AM
