What's advised to use to fix this sideskirt crack?
I cracked this EM1 sideskirt when a plastic ramp didn't keep its traction with the pavement and shot underneath the car while driving up it, and the car landed on it. The sides of the seam line up perfectly, and I can hold them together for a bit as a glue dries, but probably not for more than a minute because there is some strong push away between the two parts. I was thinking of maybe using some epoxy glue, or melting the two sides together. Is there an optimal method for this sort of clean break?
