Suspension & Brakes Theory, alignment, spring rates....
99 Civic LX Sedan Rear Swaybar
Old Oct 2, 2017 | 10:50 AM
EpicMango's Avatar
Default 99 Civic LX Sedan Rear Swaybar
I drive a stock 99 civic LX Sedan daily driver. I'm not going to lower it, the car is remaining bone stock but I did just get new Koni Orange STRT struts all around and the handling around corners has improved nicely. I also run Michelin Defender tires, so I feel I the next best thing I can do for my civic is get a sway bar. I've been researching all around, but I am consistenly reading about people with 99 EX civics easily fitting a sway bar. My question is I have an LX so does that change things?
I was looking at using a 99-00 Civic SI 13mm stock swaybar and matching endlinks because according to my research, thats all I would need. Can somebody verify this?
Old Oct 2, 2017 | 05:01 PM
98civdx's Avatar
Master Detailer
Default Re: 99 Civic LX Sedan Rear Swaybar
Nothing changes.
Everything from the 99-00 SI will bolt right on
FOR EXCEPTION
the bolts holding the bracket to the subframe are too small to fit snug in the factory subframe.
Options. You can buy the ASR bracket that slips inside the subframe and use those bolts.
OR, but 4 10mm bolts with lock washers. You will need to slightly drill out the bracket though.
Old Oct 9, 2017 | 08:15 AM
EpicMango's Avatar
Originally Posted by 98civdx
Nothing changes.
FOR EXCEPTION
I was reading that I could also use a 14mm GSR swaybar since its slightly bigger. I was looking at getting a 99 GSR swaybar with SI endlinks. Would that drop in just fine? Polishing up the parts I need to make this swap happen.
#30 D bracket, #5 99 GSR sway bar, #32 SI Endlinks/blox nonadjustables, #29 SI sway bar mount bracket and 4 10mm bolts/nuts and 8 washers.
Old Oct 9, 2017 | 04:44 PM
98civdx's Avatar
Master Detailer
You can use a Integra bar, but you will need these.
https://www.asrparts.com/collections...ant=9314235907
Old Oct 9, 2017 | 07:00 PM
EpicMango's Avatar
Eh. maybe I'll just stick with the 00 SI swaybar then. Thanks for the info, your post a while back on this exact topic is helping a lot
Emeraldbomber
24
Oct 19, 2012 10:48 PM
rice h8r
Suspension & Brakes
29
Feb 14, 2011 06:15 PM
psudo-si
May 11, 2010 09:49 AM
Milab21
Suspension & Brakes
Feb 19, 2009 12:51 AM
FifthGearOnline
10
Mar 3, 2003 01:02 PM
