I have a D15B7 1994 hatch and I want any ideas on what swaps can make it faster?
I want tips/advice on what I can either do to make the regular d15b7 faster or switch to a b16b or b18c1 or a k20/k24 swap although I heard that's near impossible. I want to make it as fast as possible stock so by the time I turbo it I won't have to run much boost to hang up v8s I know the tranny and engine are gonna have to get swapped but please ANY ADVICE HELPS ! I can do most engine work myself so labor won't be an issue thanks guys !! I'm from SpCal by the way
I think the better way to look at it is, Witch does the best when built for boost and pick that one. Build it like you would turbo it and install as na unail you do turbo. Cause best na build is irelivent once you add the turbo later. Save you heart ache and frustration later on
You'll want to head to this subforum for more technical help: https://honda-tech.com/forums/honda-...l-1992-2000-1/
LifeOnFire
11
Aug 31, 2004 09:36 PM
