2001 Accord speedometer not working with Hondata
There is a problem I cannot track down. After installing Hondata in my 2001 Accord F23 MT , the gauge cluster temp gauge no longer functions. Is there a fix for this ?
As I'm aware the gauge reads amperage , not voltage ,fed by the OE ECM . The Hondata takes the sensors signal , and uses it ,but does not convert the signal out for the cluster temp gauge.
What fix is there for this ? Jags that run , yellow box, etc , have sensor emulators and line voltage generators to convert signals for restorations . Anybody found a cure for this ?
EDIT ..TEMP NOT SPEEDOMETER>>>
jrock1234
Engine Management and Tuning
Feb 26, 2012 06:19 AM
