BAXA trans- different models for various trim levels?
Old Sep 24, 2017 | 06:51 AM
Mason Edmison's Avatar
Default BAXA trans- different models for various trim levels?
Trying to find a transmission for my 00 acord ex 2.3. Now do I NEED the a transmission unit from an ex specifically or will any 2.3L work? From what I understand, the different trim levels have slightly different gear ratios? Can anyone confirm this? My helms as well as ATSG guide does not list this anywhere... These damn Craigslist sellers are all like "this transmission will work for you", but I dont trust them as far as I can throw them...
Thanks!
Old Sep 24, 2017 | 10:46 AM
poorman212's Avatar
Default Re: BAXA trans- different models for various trim levels?
Old Sep 24, 2017 | 10:53 AM
Ha. That's about where I'm at too. I found both an LX and SE trans on craigslist. No Ex though. If I'm going to spend the time doing the rebuild I don't want it to be all whacky.
Old Sep 24, 2017 | 10:44 PM
holmesnmanny's Avatar
If the BAXA is the jdm version then all you should need to do is swap over the sensors and solenoids and be good to go.
Old Sep 25, 2017 | 11:50 PM
MAD_MIKE's Avatar
MM Gruppe B
AFAIK the transmissions between coupe/sedan and sub models don't have different gear ratios. Wagons were only slightly different with FD differences in the 90-97 modes., no wagon for us.
IIRC 2.3 transmissions are.
BAXA is Accord(Ohio) which will most likely be Coupes
MAXA is Accord(Japan) which will most likely be Sedans
M6HA is Prelude non SH, dunno about SH.
MDWA is Odyssey
MCJA is Acura CL
I haven't confirmed this, but am fairly sure it is correct.
Old Dec 21, 2019 | 05:30 PM
Chris T.'s Avatar
My accord ex is an MCJA
Old Dec 22, 2019 | 09:45 PM
MAD_MIKE's Avatar
MM Gruppe B
Original trans?
Non-original owner and a car with over 60K miles, that trans may have already been replaced.
shawnlee250
Honda Civic (2001 - 2005)
Dec 22, 2019 07:52 AM
dempsi
Aug 13, 2011 05:49 AM
webba1
May 10, 2009 02:53 PM
DelSeeYa
Mid-Atlantic (Sales)
Feb 10, 2009 12:39 PM
accord25
Jun 4, 2007 07:57 AM
