1998 civic dx hatch rear disc conversion
Old Sep 22, 2017 | 07:36 PM
98dxhatchbuild's Avatar
Default 1998 civic dx hatch rear disc conversion
hey, I am new to the forums and the Honda game. I just got a 1998 Honda Civic dx hatch and I'm upgrading all the suspension and brakes. I'm down to the brakes and I want to do a rear disc conversion using the scarebird brackets. I know I need integra calipers/caliper brackets, pads and rotors. I have searched and searched for hours but I can't find my answer anywhere...
do I use my stock e brake cables or integra e brake cables
do I use integra brake lines or what
what is a prop valve and do I need to change mine? If yes, then what do I use?
Any help will be appreciated! As well as links.
Old Sep 23, 2017 | 05:22 AM
civic402lx's Avatar
Default Re: 1998 civic dx hatch rear disc conversion
Appearantly you didnt search hard enough. Your answer can be found here.
https://scarebird.com/index.php?route=product/product&path=67&product_id=215
Ill even do your homework for you
here is a how-to:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-00-civic-scarebird-brake-conversion-write-up-2251647/
all i did was plug in scarebird bracket on google.
Old Sep 23, 2017 | 02:26 PM
94EG8's Avatar
Seagull Management
You will need Integra or '99 - '00 Civic Si brake lines and parking brake cables. You don't need to change the prop valve. '99 - '00 Si and '96 - '00 hatchbacks along with DX/HX coupe all share the same prop valve.
If you're doing this for improved braking don't expect to see a difference. You'll get a lot more out of swapping to Civic EX/Si front knuckles and Integra calipers and master cylinder than you will from swapping to rear discs.
Old Sep 23, 2017 | 02:29 PM
Okay thanks! I'm just doing it for the looks. I figured since my drums are all rusty I might as well do the conversion
CreAsiaNDoriEj6
May 23, 2011 12:57 PM
95civiccpdx
Jun 23, 2009 08:50 AM
gray89si
Aug 10, 2004 01:27 PM
LowFlyin'
Oct 20, 2003 03:49 PM
