OH FS: 2000 EBP CIVIC Si EM1 - $4500-$5000
Old Sep 19, 2017 | 08:38 AM
joey1320's Avatar
Default FS: 2000 EBP CIVIC Si EM1 - UPDATED Price $4200
So I've decided to sell my project car...
Joey L.
jleon1980@yahoo.com
Will provide phone number via PM only.
Car located in 44070.
2000 Civic Si
SALVAGE Title due to previous theft - twice.
Unknown mileage due to previous theft - current odometer reads 149xxx but not sure if correct.
1HGEM11153YL081243
So let's get the bad out of the way;
Salvage title as previously posted.
Car will need a paint job due to dents, scratches and previous paint repairs.
(I have a friend who owns a shop and he quoted ME $1500 out the door. I can talk to him about giving the next owner a deal. Can't guarantee the same price.)
CarFax shows no accidents but the front end was painted at one point by previous owner.
Exhaust B-pipe is hacked together. Will need one but currently no leaks.
At the moment the amplifier/bass is not working. Just happened on Sunday as I was driving to the Eibach meet. Haven't cared to check on it.
Due to the car being parked outside over the winter, although with two covers, the underside, not the body but suspension/brakes, is showing signs of surface rust. Should clean up fine.
The Good -
No rust on quarter panels nor fenders flared/rolled.
Everything in the car works,
I have receipts for everything.
Also items replaced within the last 3 years and 750 miles:
Engine: Brand new battery from last week. New spark plugs, ignition wires, valve cover gasket, intake manifold gasket, exhaust manifold gasket, water pump, timing belt, tensioner, thermostat/gasket, throttle body gasket, tpm sensor, all three belts, rear main seal and oil/filter. Complete engine harness gone through. All wires inspected and rewired if needed. Engine cylinders at over 190psi of compression. Extremely healthy engine.
Transmission: New Exedy (oem type) clutch kit with t/o bearing. Flywheel resurfaced. New input shaft bearing and seal, third gear synchro/sleeve, differential bearings, shifter bushings, rt side axle and seals. New slave cylinder. GM synchromesh fluid.
Exhaust System: catalytic converter, oxygen sensors, axle back, gaskets.
Suspension: EVERY item in the suspension has been replaced. Installed TruHart coilovers, upper control arms, rear lower arms, rear camber adj arms. Again, EVERY bushing, balljoint, sway bar link and rear toe adjuster arm replaced. ALL NEW!
Air Conditioner: New a/c compressor, a/c receiver/accumulator, new belt as mentioned above. Charge with fresh r134 and tested for leaks.
Power Steering: New High and low power steering lines along with pressure sensor and belt as stated above.
Brakes: New rotors all around, along with pads. New rear calipers. Fluid flushed.
Tires: Front tires in great condition over 8/32nd. Rear tires are new from NTB - cheap Aspen brand but less than 600 miles on them.
Era correct Neuspeed strut bar, DC tie bar and Comptech header (If bought complete).
Pricing: $5000 (FIRM)-package.
Vehicle plus following:
OEM rear lip.
Ebay rear lip.
OEM Fit front lip - currently installed.
Ebay front lip.
OEM front seats. Currently have DelSol seats as pictures show.
Extra OEM hood - painted B95P but poorly.
Extra Fenders - one OEM one aftermarket. Both also painted B95P but poorly.
Comptech B16 header in great condition.
$4500 (FIRM)-package.
OEM seats - will include both sets of seats, meaning the DelSol seats will still be in car.
Front Ebay Lip - Not installed - Will remove Fit lip.
Will remove Neuspeed strut bar. Dc tie bar will stay.
At the moment, Photobucket is screwing everyone with the charges so my pictures are not showing on my build thread. I have over 100 pictures of the process. You can see here: Civic SI by jrleon80 Photobucket Ask ANY questions regarding anything. I have nothing to hide nor do I need to screw anybody over. Fortunately I've been blessed to not be in any financial troubles, so the car sale is because I want to, not because I need to. Because of this, my prices are FIRM. I will not sell the anything separate other than the packages I have mentioned. Once the car sells, I will start a FS thread for the other items. DON'T ask for prices on anything else, I will not bother answering those questions at the moment. I drove the car over 600 miles this past week and it went perfect. No issues with anything other than the radio/amp issue.
Sorry for the large photos. The photos show the condition a lot better than what it truly is. Car will need a paint job.
Old Sep 20, 2017 | 05:16 PM
dmemenza's Avatar
10 Year Member
Default Re: FS: 2000 EBP CIVIC Si EM1 - $4500-$5000
I thought that comptech header looked familiar... ��
- DM
Old Sep 22, 2017 | 05:53 PM
joey1320's Avatar
I have the opportunity of buying a 1981 Kelmark GT and therefore I'm lowering the price to $4200, everything included.
stmotorsports
May 30, 2015 08:35 PM
hardtopz28
Jun 16, 2012 04:16 PM
cnydc2
Northeast (Sales)
Mar 28, 2009 06:34 AM
drastikchangez
Apr 24, 2006 04:09 PM
