Obd2b motor in to obd2a car and b20 swap questions
Okay, so I'm planning out my swap, I have a '97 dx civic coupe and I want to do a 99-00 high compression b20 swap. I did search, but I came up short. Maybe someone can direct me to a write up or something? My first question is, what plugs do I need to change on my obd2a harness to be plug and play with the obd2b engine? I know the distributors are different, but is there anything other plugs that are? Can I just use an obd2a distributor? Also, if I buy swap mounts, will I only need the rear t-bracket from the Si? Also, for my exhaust system, will an exhaust system from an em1 fit? Thanks in advanced. Any other tips and advice would be greatly appreciated, thanks.
savestheday13x2
Nov 18, 2004 10:50 AM
ricer94
May 24, 2004 04:43 PM
