Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 CR-V rough idle - when AC kicks on.
Old Sep 13, 2017 | 03:53 AM
Dan_Campbell's Avatar
Default 2006 CR-V rough idle - when AC kicks on.
Hello,
My 2006 CR-V (4Cyl) has started to idle rough and make some minor knocking noise when the AC kicks on.
This is only at idle, it runs fine while driving and quick stops at a stop sign. The issue only happens while sitting at a red light or while parked.
I have done some searches and it sounds like (Forgive the novice) Idle air control valve ? Maybe?
The air compressor was replaced last summer and it has a new serpentine belt.
I would like to ask if I'm on the right track with the idle air control valve, and if so, I may need some help finding how to clean / replace it.
Thank you, I have been reading as much as I can, but am at the point I need to ask.
Dan
Bhi Rds
May 8, 2016 06:19 PM
susy76
May 26, 2013 02:38 PM
x justin
14
Sep 12, 2006 05:47 PM
JoKarma
Sep 29, 2005 04:29 PM
