what would you do with $12k.....
Old Nov 11, 2002 | 11:35 AM
mitsuman's Avatar
Default what would you do with $12k.....
well me and a couple buddies are planning on building a semi-full-race EG hatch. we havent decided what motor/turbo/internals/etc where gunna get yet, but what would you guys get. sorry for the stupid question but im still learning a lot about honda's and i jes wanna know whats all out there. and how much **** is. TIA
EDIT: o and we still gotta buy the hatch with the 12k so put that in your expenses. thnx
[Modified by mitsuman, 5:36 PM 11/11/2002]
Old Nov 11, 2002 | 11:43 AM
mattcxb18's Avatar
Default Re: what would you do with $12k..... (mitsuman)
a rocket motor
Old Nov 11, 2002 | 11:49 AM
jas0n's Avatar
Please don't hurt me!
Default Re: what would you do with $12k..... (mattcxb18)
b18c1 t3/60-1
Old Nov 11, 2002 | 02:28 PM
Archidictus's Avatar
Unceasing Measure
Default Re: what would you do with $12k..... (couter)
Dart iron block with forged JE and Eagle internals with a hybrid turbo boosting 2.5bar, open header, drag suspension up front, gutted to hell with drag slicks.
PWN3D
Old Nov 11, 2002 | 02:29 PM
n1ek's Avatar
what type of semi-full racing would you be doing in this hatch?
Old Nov 11, 2002 | 05:39 PM
mitsuman's Avatar
Default Re: what would you do with $12k..... (n1ek)
well since its a first for us we dont want to go crzy. our goal is like low 11's.
Old Nov 11, 2002 | 06:33 PM
Kataku2K3's Avatar
EG + internally stock B16 and a Greddy turbo.... hehe j/k that is one of the stupidest ideas i've ever come up with..... My friend Kenny has a GSR with Golden Eagle sleeves, JE pistons, Crower rods, Portflow B16 head, Rev Hard stage 2C turbo with a straight T04 turbo, a 42.5mm turbo inovation wastegate, JG Edelbrock Victor X intake manifold, 900cc injectors, controlled by a Blitz SBC boost controller and Hondata 4b. It's in his EK boosting 22psi which made 505whp and 350 torque. I would put this setup in an EG and let it go... hehehehe
Old Nov 11, 2002 | 06:34 PM
Kataku2K3's Avatar
Default Re: what would you do with $12k..... (JDMspecEG6)
Traction sucks tho.... right now his best is an 11.80@119 There's just no traction through third on MT 24.5x9x13 slicks...
Old Nov 11, 2002 | 08:05 PM
mitsuman's Avatar
wow, nice hp numbers. how much did that set up run him?
Old Nov 12, 2002 | 01:42 AM
Maximus's Avatar
My b20/vtec long block is for sale. Perfect if you want to go fast in your hatch. 200whp and 130-140wtq on motors with similar mods. Do you plan to go FI or NA? I live 15 minutes away from garden grove also, you can check out my motor anytime.
[Modified by Maximus, 10:43 AM 11/12/2002]
Old Nov 12, 2002 | 05:00 AM
92sleepR's Avatar
New User
Yes. What type of racing? that has a HUGE determination on how you build up the car. I cant even begin to describe anything without knowing what the goal was.
However.... In a nutshell. Road Race = high compression NA and head work. Drag Race = turbo and bottom end work.
Suspension setups are obviously completely diferent as well.
Mike
Old Nov 12, 2002 | 06:00 AM
LoudAccord's Avatar
turbo H22a
Old Nov 12, 2002 | 06:16 AM
madman13lm's Avatar
Default Re: what would you do with $12k..... (LoudAccord)
1988 CRX HF with B18c1, skunk2 stage 2 cams, eagle rods, jpe 9 to 1 compression pistons, Mugen N1 ECU, STR intake manifold, 70MM throtle body, REVHARD 2c turbo kit, blitz bov, some underdrive pully's and cam gears... relocate the battery to the hatch in order to make enough room for the turbo, upgrade axles with race axles, pop on some nitto's or hoosiers and pump about 15-20 PSI through there and your golden...you should be making in the 400HP range, but with a car that stock weighed 1800 pounds, that will be low 11's or 10's
Old Nov 12, 2002 | 06:40 AM
PhatOptimo's Avatar
H22 and t88. Then spray on it to spool that big mo fo up or run methanol.
12K made a quick come up
Old Nov 12, 2002 | 12:38 PM
mitsuman's Avatar
Default Re: what would you do with $12k..... (Maximus)
well i plan on going FI for sure. where are you located at?
Old Nov 12, 2002 | 09:35 PM
jabroni95gsr's Avatar
240 with sr20det
Old Nov 13, 2002 | 12:45 AM
Maximus's Avatar
Sent you an IM
Old Nov 13, 2002 | 08:48 AM
Charlie Moua's Avatar
SEND it really fast to Importbuilders
add about 2k more for their ultimate B20vtec +tubro.
Old Nov 18, 2002 | 11:33 AM
SRT-WHORE's Avatar
PACKAGE 3: CRATED MOTORS 0003
<< Back Next >>
Description: "The All Motor KILLER" Package. 2 Liters.
**SMSP Header included in price.
**Portflow Designs Head Package, designed by Import Builders, only available to public through Import Builders. (This head package is not available through Portflow, only IB)
Includes:
new axles
shift linkage
ECU
wire harness
stock mounts
complete motor
Tranny included (B16A or GSR)
This is a KILLER total rebuild package for those of you that just want to be super fast. This package includes Import Builders completely revamping the motor. Sleeved block. Tranny with Honda LSD. New IB Spec forged pistons 84.5MM, new Probe rods, knifed crank, balanced crank, new bearings, new oil pump, bigger injectors, new fuel rail, new water pump, new timing belt, new alternator belt, new IB Spec valvetrain, new race cams, cam gears, Mugen chipped ECU 9500 RPM rev limit OBD1, new Clutchmasters light flywheel, fuel regulator, gauge, Hondata Stage 2NN, Injen Intake, "Special" intake manifold, Import Builders custom head package, 68MM TB, new valve seals, new head gasket, new valve cover gasket, and new CM Stage 4 clutch with new bearing. VTEC tranny with LSD, shipping included. When you get this motor package, you will not need anything. It comes with new oil, new filter, and the new radiator hoses with clamps. Just install it, break it in, and tune it.
Options:
Turbo package: no custom header, no intake, no big cams. IB "Killer" Turbo kit Add $2500.
Individual Throttle Bodies: add $1200.
Tuning options: Have us install, break in the motor and tune it, here!! Then we ship, you install, and that's it. Go race! $1500. Comes with Hondata tuning, of course.
Estimates: 220-250 HP at the wheels. (We have seen as high as 246, same build)
Price: est. $12,000 shipped Depending on car and HP desired.
Dyno Plots:
All Motor
Turbo 16psi | 17 psi
close window
That is where that money would go. IMO http://www.importbuilders.com
[Modified by SILINITY16, 3:34 PM 11/18/2002]
Old Nov 18, 2002 | 12:54 PM
EVOCELICA's Avatar
New User
go to Las Vegas and get 3000 hookers and a six pack of bud.
Old Nov 18, 2002 | 08:03 PM
irunfromcops's Avatar
Default Re: what would you do with $12k..... (EVOCELICA)
i worked the **** out of my suspension and bought an ITR swap. if i had just spent the money on beer my car would be running right now
-Sean
Old Nov 18, 2002 | 08:59 PM
smallttocs's Avatar
Default Re: what would you do with $12k..... (irunfromcops)
h22 G3 integra w/ jackson racing supercharger. all the basic i/h/e. carbon fiber hood, lighter seats, or anything else to make it not front heavy. that'll slurp up that 12k i believe.
Old Nov 18, 2002 | 09:37 PM
IntegD's Avatar
New User
Default Re: what would you do with $12k..... (smallttocs)
2500 hatch
3000 max rev kit with hondata
100 walbro
300 75lb/hr injectors
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
13250..exceeded my limit...
Old Nov 18, 2002 | 09:40 PM
Lysawy's Avatar
Default Re: what would you do with $12k..... (IntegD)
2500 hatch
100 walbro
800 quaife
4000 gsr swap
400 tuning
700 slicks/wheels
400 clutch
500 JE's
350 Eagle
200 Machine work
Same thing but H22 just gets me over any GSR out there
Old Nov 18, 2002 | 09:59 PM
Al Bundy's Avatar
Default Re: what would you do with $12k..... (Cx Sir II)
87-93 f-body 5.0 lx and use 8000 in motor work, 2000 in suspension
