Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
why wont you start
Old Sep 9, 2017 | 07:44 PM
foesick's Avatar
Default why wont you start
Hey everyone, I seem to be having a starting problem AGAIN, So every morning when I go to start my honda it will not start unless I push the gas peddle all the way down but after that im good to go. I am at a loss as to what could be the issue, to start with in the last 6 months I have put a new 02 sensor, radiator with hoses, alternator with belts, throttle body with sensors, and a fuel pump and filter. it seems as though no matter what I do I can't seem to figure out what the issue is. the only thing I can think of is a fuel leak somewhere but I am not even sure where to being looking for a leak at??? does anyone have any suggestions? I did today get an engine light coded p0171 the its the only code it has pulled.
Old Sep 9, 2017 | 11:30 PM
toyomatt84's Avatar
Sanji
Default Re: why wont you start
What kind of car is this?
Old Sep 10, 2017 | 04:52 AM
foesick's Avatar
It is an 05 civic ex sedan
Old Sep 10, 2017 | 06:26 AM
prodjay10's Avatar
does the immobilizer light stay on or does it turn off after blinking a few times?
Old Sep 10, 2017 | 06:40 AM
foesick's Avatar
It turns off after blink a couple of times once I get it started?!
Old Sep 10, 2017 | 08:03 AM
prodjay10's Avatar
a p0171 means you are running lean. Check your o2 sensors although that may not be the problem i would check else where first. when engine running lean check for hoses and vacuum leaks. clogged injectors or any where in the fuel system that will prevent it from operating properly. yeah i would also check fuel pressure etc. per workshop manual good luck.
Old Sep 11, 2017 | 06:01 AM
NDNV's Avatar
Check for a cracked exhaust manifold which is a common occurrence with these vehicles. Search on cracked manifold for more info...
Old Oct 3, 2017 | 09:07 AM
foesick's Avatar
So an update As it turns out the rubber seal that goes from the into the air box and goes over the throttle body had a small tear allowing for air to get in though it. I bought a new rubber seal and the issue has been completely fixed starts right up without having to gas it all coeds have gone away
Old Oct 5, 2017 | 04:39 AM
DumpdEJ6's Avatar
I like the tuna here
Excellent! Glad you figured it out, and thank you for updating the thread!
khakwada
Jul 15, 2012 08:57 PM
bluecoronet
Nov 25, 2010 03:31 PM
Integra4lyfe069
15
Mar 10, 2009 02:51 PM
dubzz24
Mar 2, 2007 09:14 AM
BOOSTEDgreeneg
Sep 6, 2005 10:06 AM
