tune up on b16b engine
Old Sep 7, 2017 | 05:08 PM
Mr. B16's Avatar
Default tune up on b16b engine
Quick question, could I use the same tune up kit, (timing belt, water pump, spark plugs, fuel filters, etc.) for a usdm b18c5 itr for the b16b engine?
Thanks for the help.
Old Sep 7, 2017 | 06:08 PM
White_EG1's Avatar
Default Re: tune up on b16b engine
I'm not sure how many teeth the CTR or ITR belt share so hopefully someone who knows could chime in. But everything else should be fine. Or I'm sure a quick part search seeing if the numbers are identical would work.
Old Sep 7, 2017 | 09:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, you can use ALL tune up parts from a B18C5 for your B16B engine. Timing belt, water pump, distributor cap, rotor button, spark plug wires, spark plugs.
Old Sep 8, 2017 | 05:28 AM
mk378's Avatar
Fuel filter type would be what fits the original car. Swapping the engine doesn't change that.
Old Sep 8, 2017 | 05:38 AM
Mr. B16's Avatar
Nice. Thanks for the help!
Old Sep 8, 2017 | 11:46 PM
egsleepercivic's Avatar
b16b is a destroked b18c, timing belt is the same as type r and gsr
mrinno
Sep 19, 2007 04:55 PM
Fat Chick Magnet
Jan 31, 2007 05:47 AM
1990crxsir
Jun 2, 2006 12:55 PM
jizzer671
Jun 2, 2005 12:40 AM
alleyezonme
Apr 8, 2004 08:26 PM
