97 Accord. Odometer, Spedometer not working
Old Sep 6, 2017 | 09:08 AM
willela12's Avatar
Default 97 Accord. Odometer, Spedometer not working
My v4 maunal 97 honda accord seemed to have a bad speed sensor as cruise control, my speedometer, and odometer were not working. I replaced the speed sensor and popped the fuses in and out to make sure everthing was fresh. Now, my cruise contol works but the odometer and speedometer still dont work. No check engine light Update: pulled fuse out again and now I've got the check engine light
Old Sep 7, 2017 | 03:26 PM
Nlarge's Avatar
Default Re: 97 Accord. Odometer, Spedometer not working
And the code is........
Old Sep 8, 2017 | 08:02 PM
johhnytsunammi's Avatar
Pretty common issue on these cars. I replaced my speed sensor a few times. It turned out to be the speedo itself. Just grab a cluster from the junkyard.
Old Sep 8, 2017 | 08:07 PM
Nlarge's Avatar
or go digital!
Old Sep 17, 2017 | 03:27 PM
willela12's Avatar
Where'd you get that digiatal cluster and $?
Old Sep 17, 2017 | 03:42 PM
Nlarge's Avatar
i made it and wired it myself... any digital tach or speedo will work
Old Sep 17, 2017 | 04:11 PM
angrysmileyface's Avatar
What brand of gauges fit like that? Is the wiring straight forward to the 4 connector points of each gauge?
Old Sep 17, 2017 | 04:14 PM
Nlarge's Avatar
these ones are intellitronix... there is some minor fab required. Wiring is easy.. a few vampire tabs for power, ground and signal.
Viper05
Jun 20, 2013 08:35 PM
Alwayscali
Sep 29, 2012 04:29 AM
Perfectibilist
Dec 31, 2010 07:03 PM
comptonfinest
Jul 19, 2009 07:02 AM
