H22A1 Rev Limit Possibilities - discussion of ideas
Old Sep 2, 2017 | 03:57 PM
Sleepy94's Avatar
Default H22A1 Rev Limit Possibilities - discussion of ideas
Whats the base red line for h22a1 and how high can I rev safely?
H22a1 has skunk 2 valve springs, cams/cam gears in it.
I have a P28 looking to tune it to make constant power through shifts?
Old Sep 2, 2017 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: H22A1 Rev Limit Possibilities - discussion of ideas
What series Skunk2 cams do you have ??? 8000 RPM would be pretty safe, but if the cams are more aggressive, you may be able to make power higher than that.
Old Sep 4, 2017 | 02:22 PM
Sleepy94's Avatar
It is all skunk 2 racing series not 100% sure the stage of the cam though.
Old Sep 4, 2017 | 04:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Once you get it on the dyno, your tuner can show you where it stops making power... it is typical to set your redline between 300 and 500 RPM higher than peak power.
alexthegrinch
Apr 1, 2009 04:21 AM
Civic*B16A3*Eg
Mar 3, 2007 02:02 PM
b18c1acura
Sep 1, 2004 10:54 PM
hondaboyB18C1
12
Aug 22, 2004 12:37 AM
NightHawkC5
Mar 1, 2003 04:16 AM
