Honda CR-V & Element 2WD & 4WD Element & CR-V
Heavy Duty Inner rear CV joints???
Old Sep 2, 2017 | 10:41 AM
hotroder69's Avatar
Icon6 Heavy Duty Inner rear CV joints???
Does Anyone know where I can buy Extra heavy duty "inner" rear CV joints for a AWD CRV?
Thanks
Charlie
Old Sep 10, 2017 | 11:30 AM
77amc's Avatar
Default Re: Heavy Duty Inner rear CV joints???
How HEAVY DUTY?
I assume you know that these aren't 'true' 4wd like a Jeep or Full size truck.
And with the theory of weakest link going first, if you "build up" the axles, The diff will most likely go first and that would be
much more expensive to fix/replace than a couple cv axles.
BUT, if you're planning a motor for more power, get an aftermarket drive shaft (or kit to replace any stock or non serviceable U-joints)
And you might be able to just get some chrome molly DOM that the Inner ID dims are the same as your stock axles, and cut DOM to length, insert, and weld
into the DOM. Have balanced, and install.
(DOM= Drawn over Mandrel tubing. Seamless for more strength) just if ya didn't know..
E
Old Sep 11, 2017 | 05:57 AM
hotroder69's Avatar
I have the chrome molly shafts for the rear. The front axels are already done, they're good for 400hp. I'm just working on the rear axels.
Thanks For the reply.
Charlie
K7-1Ktrevor
Appearance Build Threads
112
Apr 3, 2020 03:30 PM
insanemike24
Honda S2000
Jan 22, 2007 11:53 AM
KlawzOfDeath
Nov 10, 2004 01:35 PM
ykracing
Nov 12, 2003 09:38 AM
