Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Using a Battery Tender to Save Settings while changing battery (2006 Odyssey)
Old Aug 31, 2017 | 07:23 AM
Rossmann's Avatar
Default Using a Battery Tender to Save Settings while changing battery (2006 Odyssey)
Do I need to use a battery tender to Change out my battery on my 2006 Honda Odyssey,the parts house said I would short out my electrical system/ navigation/ onboard computer?
Old Aug 31, 2017 | 09:57 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default re: Using a Battery Tender to Save Settings while changing battery (2006 Odyssey)
Idle speed, transmission shift points, and convenience features(power windows, entertainmaint..etc) will be affected.
You will not likley "short out" anything,but you will be inconvenienced until things return to normal on their own,or in some cases are reset to normal.
So yes,use a battery tender.
Old Sep 1, 2017 | 08:49 AM
speedlever's Avatar
Default Re: Using a Battery Tender to Save Settings while changing battery (2006 Odyssey)
I think your best bet is to use a memory saver cable that runs from a 12v source (like a jump starter) to your OBD2 port.
Amazon Amazon
Example of jump starter with a 12v outlet:
Amazon Amazon
I've tried the 9v memory savers without any success. The above works in my experience.
George Knighton
Honda Insight & CR-Z Hybrid
Oct 21, 2009 05:50 PM
tC_Dragon
Feb 23, 2003 02:36 AM
