Suspension & Brakes Theory, alignment, spring rates....
Which coilover spring with KYB GR-2 on CRX
Old Aug 30, 2017 | 05:32 PM
2x0's Avatar
2x0
10 Year Member
Default Which coilover spring with KYB GR-2 on CRX
I've done some searching and I can only find info for pairing with KYB AGX.
My CRX came to me with KYB GR-2 shocks and tein springs. I would like to get adjustable height coilover springs because the drivers side of the car sits a lot lower than the passenger side.
Is there a good coilover spring pairing with the GR-2 shocks that anyone could recommend?
thanks
Old Aug 30, 2017 | 10:13 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Which coilover spring with KYB GR-2 on CRX
How old are your shocks?
Springs H tech or S tech? (Gold or green?)
GR-2 are basically replacement OE equivalent shocks, they're not going to handle much drop.
Old Aug 31, 2017 | 03:30 AM
2x0's Avatar
2x0
10 Year Member
Shocks I would assume are about 5 years old, the same age as the build.
And my springs are purple..... I was just told they are Teins
It does not sit very low, maybe 1.5" to 2.0" lower than stock I would say. Although I would like to lower it more once I get different wheels and tires that will tuck in nice. Maybe 2.5" to 3.0". So I am hearing that the GR-2's are no good anyway and I should get some full coilovers or pair with some AGX shocks instead?
Old Aug 31, 2017 | 07:36 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
1.5 to 2" is an agressive drop. Its not as mild as you think.
Any stock length shock (Koni, OEM, KYB, etc) will properly handle about a 0.5 to 1" drop on a 88-91 CRX. And you'll need fairly stiff springs.
2.5 to 3" is a ridiculously massive drop. You'll need a full body coiliver to do that even close to "properly".
Purple springs aren't Teins.
Any adjustable coilover system designed for use on stock shocks will work on your GR2's. Ebay probably shows like 800000000 listings.
Old Aug 31, 2017 | 08:34 AM
2x0's Avatar
2x0
10 Year Member
Maybe I am incorrect about how much of a drop it has now. Just seems like stock they have such a huge wheel gap. Maybe it is only 1.0 to 1.5" drop currently. I probably won't go more than 1/2" lower than were it is though, depending on how it looks. So will the GR-2's be alright or no?
Old Aug 31, 2017 | 08:36 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
If your driver side is sitting a lot lower than the passenger side, it may be that your shocks are bad.
Old Aug 31, 2017 | 09:04 AM
2x0's Avatar
2x0
10 Year Member
Alright I will just plan on getting an all new setup then. Thanks guys!
Old Aug 31, 2017 | 09:22 AM
B serious's Avatar
Shock wear doesn't affect height.
OP....no. Without using like a 600-800LB spring, your car cannot properly be lowered any further. There aren't any off the shelf shocks that will support those spring rates.
You really should be using incredibly stiff rates and/or RCA's or extended hats at your current height. Or full body adjustable coilovers.
I am using the word properly, though.
If I remove the word properly from the above sentence, we are left with "YOLO".
You can certainly buy coilover sleeves and they can certainly be set lower. The shock will just pound the bumpstop into dust and you'll need a spine doctor when you're older.
If you ARE interested in the word properly:
If you want to ride as low as your car is currently, or lower...you need a coilover whose entire case length is adjustable. That's the most simple way. There are other, more involved ways.
Old Aug 31, 2017 | 09:32 AM
B serious's Avatar
Your driver side is likely lower because:
-Note which side of the car the engine is on.
-Also note that the driver side of the car is usually the heaviest (because passengers are optional, but drivers are less optional).
-How much R&D or quality control do you think went into those springs? 5-15 minutes worth?
-Your springs may be sagging.
-Possible collapsed LCA bushing on one side.
-Etc.
Old Aug 31, 2017 | 10:19 AM
Tyson's Avatar
Driver side is always lower.
Even in UK they complain about driver side being lower, opposite to us.
Normal. Get used to it or adjust.
Old Aug 31, 2017 | 10:35 AM
2x0's Avatar
2x0
10 Year Member
The car already rides like ****. More than likely, shocks are on their way out since they aren't meant to be lowered, and previous owner bought some cheapo lowering springs that are way too stiff.
So, I will get a set of fully adjustable coilovers like I have done on my past cars. What's another $1500 in the crx money pit?
AUCivic
Honda Civic (2001 - 2005)
Jan 22, 2008 07:08 AM
CivicHP
Suspension & Brakes
Aug 21, 2006 08:36 PM
srv3fender
Suspension & Brakes
May 12, 2005 08:19 PM
crackhead
Dec 10, 2002 04:44 PM
jonoknut
Sep 8, 2002 07:24 PM
