do it yourself quick shift? I've got a good and cheap idea how but want input.
Old Nov 11, 2002 | 10:15 AM
osuPrelude's Avatar
Default do it yourself quick shift? I've got a good and cheap idea how but want input.
I was talking to some guys at my Formula SAE car meeting and we figured out that if you cut the shift linkage from the metal shifter, and weld it a bit higher, this would effectively lessen the throw, but we were unsure as to how the linkage geometry will be effective. Check out http://www.ntpog.org/mods/fifth-shifter/shifter.shtml for pics.
Peace.
Old Nov 11, 2002 | 10:21 AM
DsITR's Avatar
Default Re: do it yourself quick shift? I've got a good and cheap idea how but want input. (osuPrelude)
This is exactly what the DC sports short adapter does.'
But it raises the angle of the linkage so its harder on it...There has got to be a better way..
Maybe if you put the adapter behind the shifter...but that may not engage gear properly.....You'd have to make some prototypes.
Old Nov 11, 2002 | 10:24 AM
osuPrelude's Avatar
Default Re: do it yourself quick shift? I've got a good and cheap idea how but want input. (dsludefosho)
I wouldn't be fabricating anything, unless I needed to (we have a machine shop and a lot of stock to work with). I was thinking simply cutting the link off at the bar and welding it higher. If anyboy has any ideas feel free to share. Peace.
Old Nov 11, 2002 | 05:24 PM
DsITR's Avatar
welding it higher would work...like I said before that is EXACTLY what the DC adapter does, it just relocates it..
Welding it higher is fine, but it puts more stress on the linkage just like the DC shifter.
efyou999
Apr 19, 2010 08:07 PM
Cookiegsr
Apr 26, 2009 02:40 PM
CR-V-tech
May 29, 2008 03:22 PM
SeaBass
Jul 9, 2003 10:25 PM
SuperCivic
12
May 15, 2002 02:12 PM
