cant find obd connector
Old Aug 28, 2017 | 04:59 AM
slimster's Avatar
Default cant find obd connector
cant find obd connector on 93 honda civic .Its supposed to be on pass/side kick panel but there's nothing there accept for cars computer . can you help please . TY
Old Aug 28, 2017 | 05:15 AM
mk378's Avatar
Default Re: cant find obd connector
The 1993 model is not OBDII compatible, which was required starting with the 1996 model year. Instead it has a so called OBD1 system. Above the ECU you should find two small plugs that aren't plugged into anything. The one with two wires is used for checking codes. Put a jumper wire in it to connect the two wires then turn the key on and the codes (if any) will blink out on the check engine light. If there aren't any codes the CEL will stay lit constantly.
black0hatch
Honda CR-V & Element
38
Sep 18, 2012 08:22 PM
poppypizza
12
Apr 13, 2008 07:28 PM
stevescivic
Honda Civic (2006 - 2015)
Jan 23, 2008 10:27 PM
fe519
Nov 24, 2006 01:49 PM
slamdlude
Apr 11, 2006 03:40 PM
